FORUM FIBARO
Forum systemu FIBARO
| FAQ |  Search |  Memberlist |  Usergroups |
| Register |  Log in |
Previous topic «» Next topic
Scene not doing what i want...
Author Message
TANE
hashop.nl
Posted: 2013-03-11, 23:06   Scene not doing what i want...
The scene will run automatically when the front door opens..
and send a picture by mail.
this works fine.
At the the and I like to set the status of the frontdoor to Unlock.
This part is not working..When converting to Lua it's looks a bit different…like the 2 seconds in the camera line..this not set in the blocks.
Code:
%% properties
44 value
%% globals
if (
 ( tonumber(fibaro:getValue(44, "value")) > 0 )
or
then
    fibaro:call(91, "sendPhotoToUser", "2");
    fibaro:setGlobal("Status Voordeur", "Unlock");
89 Time(s) 34.06 KB
_________________
Enver Tanriverdi
TANE Domotica Advies
Adv.Usr.deraaij
Posted: 2013-03-11, 23:31   Re: Scene not doing what i want...
this works fine.
Code:
%% properties
44 value
%% globals
if (
or
then
LUA looks ok. The 2 is not seconds but i think the user/email which should receive the email. Can you check it with an variable without spaces?
_________________
Mark
TANE
hashop.nl
Posted: 2013-03-12, 21:20
Thx Mark,
That was the solution...
Some strage things are happening in scenes when they are time controlled.
The fallowing scene looks fine..
If Door is not locked And
Door is closed And
times is 22:30
Then
Lock the Door
Set the status to Locked
Do I need to start with time and then the other conditions?
76 Time(s) 65.18 KB
_________________
Enver Tanriverdi
Adv.Usr.deraaij
Posted: 2013-03-12, 21:28
Hi Tane,
Just to be sure you have "Start when Home Center 2 starts" checked?
_________________
Mark
TANE
hashop.nl
Posted: 2013-03-12, 21:40
Yes that one was checked and also the active scene.
both are not checked now since the door was going crazy.
looks like there are soem problems in Time and Sunset Scenes
LUA conversion looks fine...need to understand that first before converting
Code:
%% properties
44 value
%% globals
StatusVoordeur
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
while true do
if (
 ( fibaro:getGlobalValue("StatusVoordeur") == "Unlock" )
and
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "22:30")  and  tonumber(fibaro:getValue(44, "value")) == 0 )
then
    fibaro:call(98, "turnOn");
    fibaro:setGlobal("StatusVoordeur", "Lock");
fibaro:sleep(60*1000);
else
if (
and
 ( (currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7)  and  tonumber(fibaro:getValue(44, "value")) == 0 )
or
then
_________________
Enver Tanriverdi
Adv.Usr.deraaij
Posted: 2013-03-12, 22:25
Could you try:
Code:
%% autostart
%% properties
%% globals
while true do
if fibaro:getGlobalValue("StatusVoordeur") == "Unlock"
then
fibaro:sleep(59*1000);
_________________
Mark
TANE
hashop.nl
Posted: 2013-03-12, 23:28
Hi Mark,
Thanks going to test that one...looks fine..
the sleep means that the script will run every minute?
_________________
Enver Tanriverdi
Adv.Usr.deraaij
Posted: 2013-03-13, 07:13
TANE wrote:
Hi Mark,
Correct.
_________________
Mark
TANE
hashop.nl
Posted: 2013-03-13, 22:33
LUA script for the lock did work fine this evening..
Thanks.
_________________
Enver Tanriverdi
Adv.Usr.deraaij
Posted: 2013-03-13, 22:54
Thanks.
You are welcome.
_________________
Mark
jompa68
Posted: 2013-03-14, 06:28
TANE
what kind of doorlock do you have?
_________________
Regards Jonny
Global moderator on Zwaveforum.se
TANE
hashop.nl
Posted: 2013-03-14, 23:13
At the moment I'm using the Dutch system Loxx www.loxx.nl
It's running about 4 years...Loxx is no longer producing products.
Loxx is zwave enabled via 2 X Fibaro switches and the Loxx Maxi Interface.
Looking for a new systeem..
_________________
Enver Tanriverdi
SDeath
Posted: 2013-03-14, 23:31
Zoek je zoiets: http://robbshop.nl/overig...andgreep-detail
TANE
hashop.nl
Posted: 2013-03-14, 23:48
I have that one also in my own shop.
http://www.hashop.nl/Webw...e-Deurslot.html
For sure not looking for that one.
I'm looking for a good system...what can close a 3 point system without turning the cilinder
Vision is nice but can't do that.
_________________
Enver Tanriverdi
Adv.Usr.deraaij
Posted: 2013-03-15, 09:31
I would go for: Nemef Radaris Evolution Doorcontrol. (I will also when the time is right)
_________________
Mark
Display posts from previous:
Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Add this topic to your bookmarks
Printable version
Jump to:
Powered by phpBB modified by Przemo © 2003 phpBB Group
Theme created by kemustek from Forum PC
Page generated in 0.11 second. SQL queries: 14
