FORUM FIBARO
Forum systemu FIBARO
| FAQ |  Search |  Memberlist |  Usergroups |
| Register |  Log in |
Previous topic «» Next topic
Home Center - Xbmc
Author Message
Shad
Posted: 2013-03-15, 23:42   Home Center - Xbmc
LINK PLUGIN
I am glad to share the new release.
Here the repository
A lot of new feature for this addon:
- Add Virtual device in zip file
- Improvement for scene, only need 3 scene for everything
- Add PVR system (didn't try to material for that)
- Add display of playlist, I know problem on display
- Add a panel for camera system, so only need to press button for all of your scene
- Remote control compatible with music and video
- Possibility to show 8 camera on system
Here how to implement everything in you system.
- Global Variable
You need to create a global Variable with value. I will use Xbmc_Salon and for the value:
- Empty
- Movies
- TVShows
- PVR
- Music
- How to virtual device
You must import virtual device. File is in zip file.
You just need to edit ip and port on the top and in button 12, add name of new profile xmbc for slave.
- Scene
You need to Create 3 scenes and edit room with you global variable name:
Start Scene:
Code:
%% properties
%% globals
local room = "Xbmc_salon";
if ( startSource["type"] == "other" ) then
  fibaro:sleep(5*1000);
  if ( fibaro:getGlobalValue(room) == "Empty" ) then
    fibaro:setGlobal(room, "Movies");
  if ( (fibaro:getGlobalValue(room) == "Movies") or (fibaro:getGlobalValue(room) == "TVShows") ) then
    -- Code for Movie or TVShows
  elseif ( fibaro:getGlobalValue(room) == "Music" ) then
    -- Code for Music
  elseif ( fibaro:getGlobalValue(room) == "PVR" ) then
    --  Code For PVR
  fibaro:sleep(60*1000);
Pause scene:
Code:
%% properties
%% globals
    -- Code for Movies and TVShows
    --  Code for Music
    --  Code for PVR
End scene, edit Vdevice to put virtual device number:
Code:
%% properties
%% globals
local Vdevice = 104;
    -- Code for Music
    -- Code for PVR
  fibaro:setGlobal(room, "Empty");
  fibaro:call(Vdevice, "setProperty", "ui.sldPercentage.value",'0');
  fibaro:call(Vdevice, "setProperty", "ui.lblXbmc1.value",'');
  fibaro:call(Vdevice, "setProperty", "ui.lblXbmc2.value",'');
  fibaro:call(Vdevice, "setProperty", "ui.lblXbmc3.value",'');
  fibaro:call(Vdevice, "setProperty", "ui.lblTime.value",'00:00:00/00:00:00');
For me I also use global variable for weather and day/night to more possibility to have different scenario
We finish to configure HC2, now for xbmc.
Install zip file.
- Configuration of Xbmc
For configuration:
If you use virtual device, you must put the number and configure Yes for it.
Edit global variable name and you can write Season in you langage to appear proprely in virtaul device.
You can after put image number from you hc2 to change the picture for each action in Xbmc.
And for the scene just put the id number.
For the camera just use url like that but depend of you camera. For someone you can only use screenshot.
Code:
http://user:password@ip/url...
And new profile for child.
That's all, you only need to restart HC2 and normally all is ok.
Thanks to 2Fhomeawesomation to allow me to use his code and edit it for camera.
Thanks to Krikroff and Andrew to help me.
Edit:
- Version 0.0.2
- Version 0.0.3
Add Music scene
- Version 0.0.4
Add Ip camera
- Version 0.0.5
Debug Camera 3
Custom icon by place (put the icon in the folder of the addon, and write the name in the configuration)
- Version 0.0.7
Add statut with virtual device
- Version 0.1.0
Add Notification in label
- Version 0.1.3
- Add virtual device
- Improvement of Scene
- Improvement of control Music/video
- Add PVR (no system to try)
- Add playlist (display not correct)
- Add panel for camera
- Version 0.1.1
Debug
Add view 4 camera
Xbmc.vfib
Download 258 Time(s) 21.19 KB
fibaro.addon-0.1.1.zip
Download 1265 Time(s) 71.14 KB
repository.passion.xbmc.org.frodo-3.0.1.zip
Download 727 Time(s) 1.28 MB
_________________
How to:
- Your own sms Gateway
- Plugin Xbmc
- Philips HUE
stevenvd
Electronic Engineer
Posted: 2013-03-18, 08:27
Oah, it took me a few times reading to understand what exactly you made. But it's an addon for XMBC.
Just installed and tested it, it works great! Was looking for this. or actually wanted to make it myself ;) but you already did :D
great addon. Just a reminder to people. if you change the settings of the plugin (which are in: Enable addon > Services > Fibaro) that you have to restart XBMC before the changes will work.
_________________
Complete solutions by www.controlliving.nl
How to Build:
A Wake up Light
Fibaro Soft Alarm
Shad
Posted: 2013-03-21, 11:04
Fibaro, I would like to try to make also as home page et meteo the thing like that:
http://www.fibaro.com/images/eng/sys_multi.png
Does it possible to give me all picture (meteo - background....)?
_________________
How to:
- Plugin Xbmc
- Philips HUE
stevenvd
Electronic Engineer
Posted: 2013-03-21, 12:04
I was thinking of building that to.
this: http://www.theverge.com/2...y-netv-smart-tv
in combination with a UI could make a great overlay for the HDMI for if your doorbell rings orso.
And for if you want to show the weahter or different information, U can use a rasperrypi running XBMC. and you have a great combination.
Just a lot of work....
but if you want to make it for XBMC, I would love to help. Just don't have a lot of time at the moment ;)
_________________
How to Build:
A Wake up Light
Fibaro Soft Alarm
Shad
Posted: 2013-03-21, 12:51
I have huge multimedia network.
I connect parent's and brother's house and my network with ubiquiti antenna. So actually I have 4 HTPC and 3 raspberry and 2 House using HC2. And all xbmc are connected to my server and I use cardsharing for every body have pvr.
But before to do that I want finish a feature on my plugin.
stevenvd
Electronic Engineer
Posted: 2013-03-24, 16:46
Do you think there is a possibility to know the difference between playing videos (movie or shows) or music...
As I want different scenes to launch. for the movie the lights need to be dimmed. But if I turn on some music I don't want anything else to happen...
By the way I made a nice scene. (simple but effective)
If the doorbel rings. it sends a notification to the XBMC. and if the movie is playing, pause it...
and then, turn on the Chime of the everspring doorbell.
_________________
How to Build:
A Wake up Light
Fibaro Soft Alarm
Adv.Usr.deraaij
Posted: 2013-03-24, 17:14
Yes, using json: http://wiki.xbmc.org/inde...t_is_playing.3F
_________________
Mark
stevenvd
Electronic Engineer
Posted: 2013-03-24, 17:16
Ah thanks! Stupid, missed that one!
_________________
How to Build:
A Wake up Light
Fibaro Soft Alarm
Lauri
Posted: 2013-03-24, 17:55
How do you send notification to XBMC? Does it show up on the screen?
_________________
Get Your preconfigured Fibaro solutions here: http://shop.indome.ee/
Tell us what You need and we ship it to You configured so just "plug & play"
Shad
Posted: 2013-03-24, 20:42
I going to include the music also.
For notifications you need to create one by device for the moment until I can found a lua code to do that.
Edit: but I must finish an other code to get the transfer of movie alone. But not so easy to do that. I must also finish to reconfigure my HC2. Too many test on it :-)
Adv.Usr.deraaij
Posted: 2013-03-24, 20:51
tcp example:
Code:
{"jsonrpc": "2.0", "params": {"message": "There is someone at the door!", "title": "HC2 Notification"}, "method": "GUI.ShowNotification", "id": "GUI.ShowNotification"}
lua example:
Code:
tcpSocket = Net.FTcpSocket("192.168.1.22", 9090)
bytes, errorCode = tcpSocket:write('{"jsonrpc": "2.0", "params": {"message": "There is someone at the door!", "title": "HC2 Notification"}, "method": "GUI.ShowNotification", "id": "GUI.ShowNotification"}')
if errorCode == 0
then
  -- printing log under virtual device
  fibaro:log("transfer OK")
else
  fibaro:log("transfer failed")
_________________
Mark
stevenvd
Electronic Engineer
Posted: 2013-03-24, 21:14
@Shad, thanks for the fast respond ;)
You can also use predefined variables for different messages... so you can show a different message if somethings happends....
@Lauri yes, they show up on the screen :)
_________________
How to Build:
A Wake up Light
Fibaro Soft Alarm
Lauri
Posted: 2013-03-24, 21:45
Hmm, can you explain it more simple for me... I do not understand at the moment - how to send notification to screen of my xbmc
_________________
Shad
Posted: 2013-03-24, 23:16
With virtual device.
You can find all your answer on previous post for xbmc.
deraaij,
Problems with the HC2 are:
- Virtual device don't have access to data like Variables.
- You can't use Net.FTcpSocket from scene.
- We can't send variables from scene to virtual device like local test = fibaro: getName
to the virtual device. Juste that can be very nice to not have 20 virtual device.
These problemes block good sript.
_________________
How to:
- Plugin Xbmc
- Philips HUE
stevenvd
Electronic Engineer
Posted: 2013-03-25, 08:37
@Lauri:
make a virtual device with the Ip of your XBMC Machine.
the port you need is 9090
in the screenshot you can see how I send a notification to XBMC.
The code again here:
command:/jsonrpc?request={"jsonrpc":"2.0","method":"GUI.ShowNotification","params":{"title":"TITLE HERE","message":"MESSAGE HERE"},"id":1}
then just put your message where mine says: Message here.
and the title where it says title here.
and your done :D
1055 Time(s) 19.87 KB
_________________
How to Build:
A Wake up Light
Fibaro Soft Alarm
Display posts from previous:
Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Add this topic to your bookmarks
Printable version
Jump to:
Powered by phpBB modified by Przemo © 2003 phpBB Group
Theme created by kemustek from Forum PC
Page generated in 0.16 second. SQL queries: 14
