FORUM FIBARO
Forum systemu FIBARO
| FAQ |  Search |  Memberlist |  Usergroups |
| Register |  Log in |
Previous topic «» Next topic
IR transmitter working with HC2 ?
Author Message
Dennis
Always Learning
Posted: 2013-05-22, 18:05   IR transmitter working with HC2 ?
Is there any IR transmitter (like the SQ Blaster, iTach ) that is working good with HC2? So i can control IR equipment tv's, media players, Roomba's etc. ?
_________________
Maybe a lot to Learn :)
elmips
Posted: 2013-05-22, 18:22
I suppose Kira128 would work with HC2 as this is a standalone webserveur who can be controlled with GET command from an HC2 virtual device.
not tested myself anyway.
Plan to do it someday ! ;)
Here is some infos about KIRA128
Shad
Posted: 2013-05-22, 20:28
KIRA128 works great, you just need do call url from virtual device.
_________________
How to:
- Your own sms Gateway
- Plugin Xbmc
- Philips HUE
GrZeCh
Posted: 2013-05-22, 22:49
I've managed to make Raspberry Pi work with IR transmitter and receiver. I'm using Raspbmc Raspberry system so I have also media center connected to my TV and with installed lighttpd server and simple PHP file I can send TV, blue ray player commands (which remotes I've read using IR receiver) using simple GET URL from HC2 virtual device.
Raspberry pinout:
http://img577.imageshack....irev2pinout.jpg
How to connect IR receiver and transmitter:
http://randomtutor.blogsp...spberry-pi.html
How to configure lirc under linux (Raspbmc SSH access is pi/raspberry):
http://alexba.in/blog/201...he-raspberrypi/
and how to install lighttpd with PHP (sorry but only in Polish language on this website but you will probably find other english blogs telling how to do that):
http://malinowepi.pl/post...erwer-www-i-php
so for a price much lower than Globalcache devices you have IR transmitter, IR receiver and media center which can read data from network samba or NFS share or of course from some USB connected HD or pendrive.
Display posts from previous:
Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Add this topic to your bookmarks
Printable version
Jump to:
Powered by phpBB modified by Przemo © 2003 phpBB Group
Theme created by kemustek from Forum PC
Page generated in 0.08 second. SQL queries: 13
