FORUM FIBARO
Forum systemu FIBARO
| FAQ |  Search |  Memberlist |  Usergroups |
| Register |  Log in |
Previous topic «» Next topic
Home center Lite
Author Message
mpatel0902
Posted: 2014-02-21, 12:27   Home center Lite
Guys take a look........... HC Lite
[ Added: 2014-02-21, 16:59 ]
Any one have any idea about the specification of HC lite
517 Time(s) 58.17 KB
321 Time(s) 66.77 KB
HOme center lite
301 Time(s) 1004.75 KB
stevenvd
Electronic Engineer
Posted: 2014-02-21, 15:04
These photos have been around for a while. No one really knows the details. Their will probably be a lite or new version somewhere this year. But I don't think it will be soon. they are working very hard on the new Motion sensor and the new OS 4.xx
_________________
Complete solutions by www.controlliving.nl
How to Build:
A Wake up Light
Fibaro Soft Alarm
ivan.ruban
Posted: 2014-02-21, 18:17
It looks interesting. I am very curious about the price it will have.
With adequate price Fibaro can get many more users. I guess the price is the main factor why people selects Vera or Zipato.
_________________
VeraLite
Fibaro: 7 dim, 3 plug, 2 univ, 3 switch, 1 flood, 3 D/W, 2 RGBW, 1 multi
Everspring: SP103, SP814, temp/hum, siren, smoke
Other: Philio, Danfoss LC, HRT4-ZW/ASR-ZW, 2 ZW.Me dimm, QEES dim, Aeon4-1, Vision shock, Tenvis JPT3815W, GC WF2IR
wasil
Posted: 2014-02-21, 22:15
It will be half price of Home Center 2 and released really soon as I know. Keep Your finger crossed ;-)
_________________
Kitesurfing is my life :D
ivan.ruban
Posted: 2014-02-22, 06:54
Thanks for info wasil. It sounds very promising. I hope also the light version won't have any functional limitations.
_________________
VeraLite
rantta
Posted: 2014-02-22, 08:50
Of course it has software limitations, or it would not be lite.
ivan.ruban
Posted: 2014-02-22, 10:07
If you take a look in Vera Lite and Vera 3 - it is mostly only hardware that differs ( http://wiki.micasaverde.c...n_of_Vera_units ). The functionality in software is the same in both versions of controllers. The only difference in software is a different design in GUI.
Some people also say that Vera Lite cannot run more than 50 devices. But that is just not recommended because the hardware is not fast enough. Nevertheless there are users who run more than 50 devices on Vera Lite and it works fine - http://forum.micasaverde....hp?topic=9413.0
Thus I expect the same approach in Fibaro. Of course the hardware will be cheaper in Fibaro Lite version and thus perfomance will be slower. But the functions in software must be the same IMHO.
_________________
VeraLite
rantta
Posted: 2014-02-22, 10:40
That is one possibility. Another is that it would be aimed for less nerdy people, to Average Joe. So, maybe less power inside, but also limited functionality like no lua-coding etc.
There is so many ways to limit things. There still has to be gap big enought to make full version tempting enough for geeks that really want to control and automate things.
Slowing commands makes the product poor, no one want's sluggish box that has to be waited on every command. It is not good for Fibaros "Polished" and sleek brand.
We'll see.
wasil
Posted: 2014-02-22, 14:04
As far as I know it will be as fast as Home Center 2 but with some limitations if it goes to software.
_________________
monions
Posted: 2014-03-03, 16:54
Just to let you know - the Home Center Lite (HCL) has been released today.
Vesternet have the first stock arriving tomorrow (Tuesday 4th March).
We've already announced this to our customers and stock is selling out fast.
So if you'd like to secure one, then place your order quickly
http://www.vesternet.com/...ome-center-lite
There is also a complete product presentation on the 'Manuals' tab
_________________
~ Mark
www.vesternet.com
ivan.ruban
Posted: 2014-03-03, 19:01
Copied from vesternet:
Quote:
The main differences between the Fibaro HCL and the HC2 are:
Plastic casing (HC2's has an Alloy Case)
No LUA
No LiLi
No VOIP
I guess everybody can live without lili and VOIP. Anyone who use VOIP by the way? :-D
So basically it is just LUA that is different. So if person doesn't need virtual devices and complex scenes it is more than enough for basic installation with HC Lite. And it is the half of the price of HC2 :!:
I can see that interface differs as well. It is interesting to get a feedback on this GUI from someone who orded a lite version.
What I can see extra in a lite version:
1) Possibility to connect external module with GSM. That must be available in a full HC2 version IMHO! Good that you thought about it.
2) Possibilityto connect external battery. That was discussed before, f.ex. here: http://forum.fibaro.com/viewtopic.php?t=1373 Any HC2 must have internal battery with auto off logic when the battery is too low!
_________________
VeraLite
deanrparry
Posted: 2014-03-03, 19:12
No gsm or battery solution for hc2 is there even connectivity for them? HC Premium or something will pop up?
Shad
Posted: 2014-03-03, 19:39
I think that is the job of gateway connection ;)
_________________
How to:
- Your own sms Gateway
- Plugin Xbmc
- Philips HUE
deanrparry
Posted: 2014-03-03, 19:40
Very true but there is a weird connector on the lite judging by images?
rantta
Posted: 2014-03-03, 19:45
Does Lite lite support http-requests?
Display posts from previous:
Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Add this topic to your bookmarks
Printable version
Jump to:
Powered by phpBB modified by Przemo © 2003 phpBB Group
Theme created by kemustek from Forum PC
Page generated in 0.08 second. SQL queries: 14
