FORUM FIBARO
Forum systemu FIBARO
| FAQ |  Search |  Memberlist |  Usergroups |
| Register |  Log in |
Previous topic «» Next topic
HC2: Fibaro home center server not responding
Author Message
byackee
Posted: 2012-05-28, 15:30   HC2: Fibaro home center server not responding
I have a home center 2 server since 2 month, I have 30 zwave modules (dimmer, switch, sensors, etc..)
I created 10 scences and one day the home center tel me "HC2: Fibaro home center server not responding".
I can't do any actions with my box.
Somebody have a same probleme?
Thank you
Krystian
FIBAR GROUP
Posted: 2012-05-28, 16:28
Dear Sir!
You can't create/restore backup? Did You try to restore system from recovery mode?
byackee
Posted: 2012-05-28, 16:32
I restore last backup and few minutes la ter server not responding. How restore in recovery mode?
Thx
Krystian
FIBAR GROUP
Posted: 2012-05-28, 16:43
Please unplug power cable, and during plug again press recovery button (in the rear of the box). Then it should enter Recovery Mode, where You need to press "Przywróc" button (red button in recovery mode)
byackee
Posted: 2012-05-28, 19:12
I restore my box with recovery mode and upgrade to 1.027, when i want to add devices I have same message " HC2: Fibaro Server not responding".
Help me plz
byackee
Posted: 2012-05-29, 14:59
I try many things during few hours, home centre 2 tell me server not responding. I think toi return my box in warranty because it is useless.
Krystian
FIBAR GROUP
Posted: 2012-05-29, 16:28
Dear Sir!
To help You probably we will need to remotely check Your Home Center 2. Can You install Team Viewer in Your computer? We will check remotely what is happening in Your device. support@fibaro.com
Pascal
Posted: 2012-06-03, 15:58   Same problem for me
Krystian wrote:
Dear Sir!
Hello ,
I have the same problem ... impossible to do something , i receive the error HC2: Fibaro Server not responding
Can you help me ?
Kind regads
Pascal
ChrisVDD
Posted: 2012-06-03, 20:44
I have also the same problem father updating to 1.28
Christophe
byackee
Posted: 2012-06-04, 06:46
Do you need SSH or telnet access to the box for investigation? I can open and redirect port 21/22 to the box if you want?
Byackee
ASTECH44
Posted: 2012-06-04, 07:55
HI
I haved the same message when i upgrade to 1.026.
I have test the solution proposed by Krystian and now my HC is in 1.028 and that's OK.
The difficulty is that Factory Restore is in Polish language.
" First of all If You have all Your data in backup, please try recovery mode and "Przywroc" red button. It will make factory reset to Your Home Center, and I hope it will help! To enter recovery mode please unplug the device and during pluging again please push recovery button in rear part of the box. Then when system will enter recovery mode please push "Przywroc" button. System will restore to 1.009 ver and then go into standard control panel and restore Your backup, then try to update Your HC2"
Thanks Krystian
_________________
Fibaro Home Center 2 v3.580
Wall Plug, FGS-221 , FGD-211, FGBS-001 Universal Sensor , IPX800 & 880
HSM02-1-1V1, SP814 Motion detector ,SF812-1 Smoke Sensor ,Danfoss Live Connect,Vivotek IP & TrendNet Camera,Home Energy Meter DSB09104-ZWEU_3 sondes
byackee
Posted: 2012-06-04, 08:20
I do recovery and i update my hc2 but i haven t got a backup. Thé server still not responding.
Kuuno
Posted: 2012-06-04, 11:30
hei
just to make myself understand better, pls send a screenshot of the error
thanks!
Kuuno
_________________
Get Your preconfigured Fibaro solutions here: http://shop.indome.ee/
Tell us what You need and we ship it to You configured so just "plug & play"
Pascal
Posted: 2012-06-04, 11:37
I had the same error , and after the reboot oh my HC2 i receive the following page now ... :
screenshot
403 Time(s) 17.55 KB
byackee
Posted: 2012-06-04, 16:59
Screenshot attached files.
491 Time(s) 54.22 KB
Display posts from previous:
Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Add this topic to your bookmarks
Printable version
Jump to:
Powered by phpBB modified by Przemo © 2003 phpBB Group
Theme created by kemustek from Forum PC
Page generated in 0.1 second. SQL queries: 14
