FORUM FIBARO
Forum systemu FIBARO
| FAQ |  Search |  Memberlist |  Usergroups |
| Register |  Log in |
Previous topic «» Next topic
Scene programming tutorial?
Author Message
DAWO
Posted: 2012-09-15, 11:18   Scene programming tutorial?
I have tried to find any documentation in English which will explain how to program scenes in Fibaro Home Center 2 in much greater depth then what is offered in 19 page pdf brochure issued by Fibaro and downloadable at their web site.
Unfortunately I have so far not been able to find any at all. What would be great would be some kind of manual that explained the overall structure of the programming together with ample examples so that you could easily adopt those and use them in your own house…
Anyone out there who has found anything?
If not, could I just post simple examples of scenes that I wish to use in my home on this site and get help with "best practice" on how to programme these? (e.g. "Turn on one lamp at a certain time of the day and then turn it off sometime later", etc)
Thanks!
SHCaus
Posted: 2012-09-15, 14:18
I would agree that there needs to be more precise documentation.
For people that have coding experience then the scenes will be much easier to setup as it is almost like sudocode.
For those that don't have any previous coding experience then it would be harder to understand as you have to think logically when setting up the scenes.
For the example you gave you would need:
INTERVAL BASED (the day and time you desire)[Red]
THEN [Yellow]
DEVICE [Blue] = ON
For the scene to turn the light off you would do the same except choose the other time of the day, and change the device option to OFF.
I'm sure there are people on here willing to help :)
davedotnet
Posted: 2012-09-17, 14:42
You were probably referring to this 19 page document, but just in case you weren't ;-)
http://materialy.fibaro.c...1_New_Scene.PDF
It's a very simple scene but it demonstrates some of the concepts.
_________________
Fibaro Home Centre 2 - Version 3.341
Vitrum Switches (25), HeatMiser Heating (14 x PRT-N 12V Thermostats), NC601 Heatmiser RS485 TCP/IP Server,
42 x CAT6 points, Vivotek IP Cameras, Fibaro Universal Sensor, Horstmann HRT4-ZW+ASR-ZW
Software Developer
SunPower
Posted: 2012-09-19, 00:21
I agree with the request for more learning material, if possible instruction videos.
esencia
Posted: 2012-09-19, 12:53
Totally agree with you!
Display posts from previous:
Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Add this topic to your bookmarks
Printable version
Jump to:
Powered by phpBB modified by Przemo © 2003 phpBB Group
Theme created by kemustek from Forum PC
Page generated in 0.08 second. SQL queries: 13
