looking for a windsensor 230v with wired motor control
kroeatschge replied to kroeatschge's question in Other Devices / Third-party devices
Thank you, but doesn't have to be z-wave as I just want to use the existing fibaro roller shutter. should be 230 volts. - Today
Hi, HCL3 QuickApp limit 10 is ridiculous.Most non z-wave devices has no direct Fibaro support, so QuciApp must be implemented. Basically only 10 devices can be used with HCL3. Z-wave has 40 devices limit, QuickApps should share same limit. At least total 40 devices no matter if z-wave or QuickApp must be allowd.
Dequinho joined the community
Alex777 joined the community
Seba999 joined the community
Witam serdecznie, Jakiś czas temu pewnie ponad rok temu wysłałem na support fibaro parametry urządzenia aby wykonali szablon. No i na tym koniec nic się nie dzieje. Chętnie sam bym go zrobił tylko za bardzo nie wiem jak się do tego zabrać?? Gdy dodaję ustawienia w konfiguracji (zaawansowane), po zapisaniu znikają, coś pewno robie nie tak. Może jest gdzieś jakiś poradnik jak to zrobić, po ludzku Urządzenie to między innymi Grenton RELAY 2 kanałowy oraz Keemple włącznik światła. Z góry bardzo dziękuję za pomoc Pozdrawiam
schmurgel joined the community
Did Tibber support reacted on your question? If it doesn’t work in the Tibber Explorer, it also won’t work in the quickapp. Ofcourse the other way around, is also the case. If it workes in the Tibber explorer, it should work in the quickapp, otherwise the quickapp is at fault. I can only test with the test token and test HomeID. That test interfaces with the Tibber servers and it workes. You could give it a try to change the token in someting you are sure is faulty. Then see if you get the same error. The same test with the homeID. It won’t solve the problem, but you will know where the error comes from. Any other users with the same problem? (If it wouldn’t work for a week with other users, someone would have post a question or reaction?)
mapko joined the community
Fibaro NC3 stops updating Voltage on Qubino 3-phase meter
m.roszak replied to PiotrTheGreat's question in Home Center 3
I meant that the behavior of those modules is inconsistent - sometimes those can work ok for several weeks, then - they just stop to report some or all values. It is something in the device firmware, not the hub - we already confirmed this. That is why we changed the default configuration some time ago to workaround a bit this issue. Of course, they did not change anything remotely, if you would like - download the logs dump from the hub and I will make sure that the device is just not sending us the values and it is not an error in the hub somehow - just create a support ticket and put the logs there, include the information about device ID in the system. -
PiotrTheGreat replied to PiotrTheGreat's question in Home Center 3
I'm not sure I understood you well. Please explain: Qubino stopped updating "Qubino 3-phase meter" https://qubino.com/products/3-phase-smart-meter/smart-meter-3phase-tech/ How can it be? Do they switch off some functionality remotely? Fibaro HC3 prior to 5.154.37 showed voltage and after upgrade it does not. No change from Qubino Smart Meter (it was not upgraded / changed in any way) The only thing was upgrade to 5.154.37. Piotr -
[Solved] Aeotec Siren 6 not showing in the Yubii App
awlieser replied to awlieser's question in FIBARO Mobile
Thanks for the clarification! Cheers Alfons -
Traktor109 joined the community
Hi Eddy, I‘m in contact with Tibber Support - so far no solution. When I look at HC debug log I see the following: [28.03.2024] [13:53:48] [ERROR] [TIBBER LIVE ID:1916]: WebSocket error: Connection failed Cheers Alfons
Nicolaus joined the community
m.roszak replied to awlieser's question in FIBARO Mobile
Actually, it is for a purpose, it's a siren - to be used in scenes in correlation with the alarm panel if someone is interested. Due to the lack of actual use cases to be shown as an actor - it is just hidden. -
I recently bought a new iPhone, and transferred all my apps and data from the old one. This includes the two apps for my HC2, the old Fibaro app and the newer Yubii app. They both immediately accessed the HC2 as before, and display the HC2 values correctly. However, when I check the HC2 interface Configuration/Access control/Mobile units list, my new phone is not on that list. I recognize the UDID for my old phone and the corresponding device id, but not the new one. I need to identify my new phone as a device, to update my scenes to send push messages to the correct id. It seems that the data transfer from old to new iPhone bypasses the trigger which automatically generates a new device when the Fibaro/Yubii apps are first installed. How do I make the HC2 recognize that there is a new iPhone to include in the list? Do I need to reinstall the apps?
@assosboy Do it step by step. From top to down.
Fabir replied to awlieser's question in FIBARO Mobile
@awlieser The same issue here with the sirene6 on android and Yubii 1.21.1. The sirene6 has the latest firmware. Therefore I use it only in scenes. -
Hi, I have Govee Outdoor String and it only controlls white color. In Yubii I see no RGB controlls. Is there any fix for it?
The topic should be "Qubino stops reporting voltage" - that is not on the hub side. The way the hub works, if the report is sent we are processing it, it is not like one of the values may be ignored and the rest are ok. We contacted Quibino about some issues in the devices (problems with reporting values, not working interval-based reporting) but "they are no longer updating the 500 series devices" and those are on the EOL (end-of-life) phase. -
Yah the API dont work, it looks like missing info
Im also looking to reset meters as history because I'm testing and do not like that info to be carried forward did anybody find a " real" solution that works, Have tried the API route and that looks not to work
I simpy Cant get this to work, are you able if you have time to more step by step guide ?
Karol_88 joined the community
ahh okay thanks
If you use sunset/sunrise the second field must be an offset, not * fibaro.cron("sunrise 0 * * *", function()...etc otherwise it would mean something like every possible offset to sunrise, which doesn't make sense...
Jan it is complaining about sunrise and sunset fibaroExtra.lua:70: Bad date specifier 'sunrise' using it like fibaro.cron("sunrise * * * *", function()...etc fibaroextra version fibaro.FIBARO_EXTRA = "v0.964"
Thabit joined the community
szczepan.w joined the community
Smart Implant setup for NICE MCA2/
Pamaliska replied to rasenkantenstein's question in Smart Implant
Hi, could you post you current setup connection diagram? Thank you. -
Hi, I installed the Aeotec Siren 6 today on my HC3. The device is shown as configured and is working properly, when accessed via the web interface of the HC3. Strangely enough, it doesn‘t show in the Yubii App (IOS). Any idea? Thanks! Cheers Alfons
Then HomeID would be the fault, but I wouldn't expect the HomeID to change. Let's wait for the Tibber Support response.
Hi Eddy, did that - unchanged. But still no joy in explorer. Maybe it‘s the HomeID. Cheers Alfons
I think you can check your token at https://developer.tibber.com/ and login with your Tibber login.
