ReadAndSendGlobalVariables_HC3 1.0.0
   (0 reviews)
This script allows you to read out the global variables under HC3 and send them by mail.
In contrast to HC2, I did not find a way to read out all variables directly under HC3 and therefore created an array, which must be filled once with the existing variables (or when new ones are added or old ones are deleted) of YOUR HC3.
Then this works very reliably. Just create a scene with a timed trigger and paste the code on the right. Then adjust the variables and what title you want to give them. Then this is displayed easily readable in the eMail (see screenhot)
Suggestions for improvement are welcome.
To read all global variables on HC3 platform please use as described below:
for i,in pairs(api.get("/globalVariables")) do
     print(j.name, j.value)
It will print out global variable name and value....
By the way may I suggest to have an option to send QA and Scenes global variables also.
Edited by cag014
