Smarter Coffee VD 1.0.0
   (1 review)
Smarter Coffee VD
Hello friends of Fibaro and a good cup of coffee!!!
When I became proud owner of Smarter coffee machine, I didn't know that Smarter is making smart appliances that are actually not connectible to home automation. I have ask them several times if they plan to publish coffee machine API or what ever is needed so that it can became connected part of our every day smarter home. What is the use of smart coffee machine if you have to grab mobile phone every morning in bed to tell it that you want coffee to be brewed!! The answer was always "maybe soon". So I get tired of waiting!
I was intensively searching the wast land of internet and just few days ago finally stumble on at least some kind of solution provided by Simone Margaritelli the evilsocket and Aden Forshaw. Of course their solution is written in python but for me is unacceptable to have additional server even on small PI just to start coffee machine. So done little experimenting because this coffee machine has really simple commands in bytes where first byte is command and last byte is marking end of command. Here is what evilsocket and Aden found and I provide translation to our LUA language with this little knowledge I have just in case if you want to experiment further or do similar VD for iKittle 2:
-- Smarter coffee commands:
command      - hexadecimal            - decimal format used in LUA
brew         = "7"                    = "7"
reset        = "\x10"                 = "\16"
get wifi aps = "\xD"                  = "\13"
toggle grind = "\x3c\x7e"             = "\60\126"
set strength = "\x35%\x7e"            = "\53\%\126" where % = 0-2 (weak, mid, strong)
set cups     = "\x36%\x7e"            = "\54\%\126" where % = 1-12 cups
set config   = "\x38\%1\%2\%3\%4\x7e" = "\56\%1\%2\%3\%4\126" where %1 = strength
        %2 = cups
        %3 = mode (grind, filter)
        %4 = warm time
warm % min   = "\x3e%\x7e"            = "\62\%\126" where % = 1-30 min
warm stop    = "\x4a\x7e"             = "\74\126"
-- Smarter coffee response
response         - hex         - decimal counterpart
brewing or OK    = "\x03\x00~" = "\3\0~"
already brewing  = "\x03\x01~" = "\3\1~"
invalid argument = "\x03\x04~" = "\3\4~"
no carafe        = "\x03\x05~" = "\3\5~"
no water         = "\x03\x06~" = "\3\6~"
low water        = "\x03\x07~" = "\3\7~"
reset ok         = "\x03i~"    = "\3i~"
-- In LUA backslash \ is used to mark byte in the string so it cannot stand alone or be
-- last character in string like this: "\" or this "\56\". ''So this is problem if you want
-- to combine different values in string commands like for changing number of cups
-- since it is impossible to join "\54\" ..cups.. "\126". 'Only possibility that
-- came across my mind is to use table with predefined strings for coffee strenght,
-- number of cups and Keep wamring time as listed bellow.
local comm = "\56";
local cups = {"\1", "\2","\3", "\4","\5", "\6","\7", "\8","\9", "\10", "\11", "\12"};
local stre = {"\0", "\1","\2"};
local mode = {"\0", "\1"};
local time = {"\5", "\10", "\15", "\20", "\25", "\30", "\35", "\40"}
local endb = "\126"
-- example of building command for setting coffee machine default settings
local command = comm..stre[2]..cups[2]..mode[1]..time[1]..endb
I should actually put this part in developer section but here it is for those of you who like to play with it.
So here it is SMARTER COFFEE VD V0.1 first release
Smarter_coffee.vfib.json
To be able to use this VD you will need following devices:
1) HC2 - VD will work only on HC2 due to LUA code (Will try to do HCL version but will not be with all possibilities as LUA version)
2) Smarter Coffee machine with latest firmware V 22.0 (will work with older version but you will not be able to stop Keep warming or set it to 40 min)
3) FGWP smart plug or any other similar. It is needed to monitor coffee machine consumption from which is determined if it is brewing, keep coffee warm or stopped
Also after importing VD to your system you need to setup IP address and TCP port. Since it is not possible to get IP address of your precious coffee machine from original app you will need some other app to find it for you. I used Fing on my iPhone. TCP port is 2081. And it should be entered on advanced tab of the VD:
Before you start using VD first you will need to define some global variables in global variable panel. I was planning to add code to do that part for you, but since Fibaro is constantly changing API on HC I decided to leave this part to you. Besides you can put values of global variables in your language but then you will also have to change few things in code of each button and main loop. Will explain later what to change.
So this are global variables that are needed for Smarter coffee VD to work properly:
First are variables (top part in panel):
Name of variable - possible value that you must enter when adding (DO NOT leave 0 if is not possible value!!)
SmarterCups       - possible values: between 1 and 12. Do not leave 0. Keeps number of cups of coffee.
SmarterStrength  - possible values: 0 - Weak, 1 - Medium or 2 - Strong.  Keeps value of coffee strength
SmarterWarm      - possible values: 5, 10, 15, 20, 25, 30, 35 and 40. Keeps time for how long coffee will be kept warm
Following are predefined global variables (bottom part in panel):
Name of variable - possible values that you must enter in order I put them here bellow.
SmarterBrewed   - possible values: No, Yes. Used to prevent starting brewing twice in a row. This is filter coffee and filter is better to cleaned after each use.
SmarterDefaults  - possible values: table that contains coffee machine default values for strength, number of cups, mode (Filter or Grind) and time to Keep warm. You need to define only one value with name Table and then save. Open again to edit and then delete Value2. VD will take care of the rest.
SmarterMode      - possible values: Filter, Grind. It is self explanatory :-)
SmarterPush       - possible values: No, Yes. It is used to send push notification only ones from VD main loop when coffee is ready
SmarterStatus     - possible values: Ready, Not ready, Brewing, Keep warm, Faulty, No carafe, No water, Low water. Status of the machine.
SmarterUseDef   - possible values: No, Yes. If using default values then VD needs to restore to those values after brewing is finished.
For global variables SmarterBrewed, SmarterMode and SmarterStatus you can use words in your language but if you do then you will have to change in code as follows:
-- GLOBAL VARIABLES -- enter names and value mapping of your
-- global variables or leave as it is and add to variables panel
-- "SmarterStatus" is predefined global variable. Enter your
-- name and mapping of values
local smarterStatus        = "SmarterStatus";
-- change value mapping to corresponds to your values in your global variable
local smarterStatusMapping = {ready="Ready", notready="Not ready", brewing="Brewing", warming="Keep Warm", faulty="Faulty", nocarafe="No carafe", nowater="No water", lowater="Low water"};
-- "SmarterMode" is predefined global variable
local smarterMode          = "SmarterMode";
local smarterModeMapping   = {filter="Filter", grind="Grind"};
-- "SmarterWarm" is global variable possible value 5 to 40 in
-- step of 5
local smarterWarm          = "SmarterWarm";
-- "SmarterBrewed" is predefined global variable used to change
-- machine status
local smarterBrewed        = "SmarterBrewed";
local smarterBrewedMapping = {Yes="Yes", No="No"};
and this has to be done in all code for each button and main loop!
Next step is to add icons and then do mapping of their IDs in the code. Here are the icons in order and with their names in code:
Main icon that you will set as default on the VD and all buttons except on button Brew and Keep warm:
In code is named iconBrewing so you will need ID and also set it up on Brew button:
In code is named iconWarming so you will need ID and also set it up on Keep warm button:
in code is named iconNoCarafe so you will need ID:
in code is named iconLoWater and ID is needed:
in code is named iconNoWater and ID is needed:
in code is named iconFilter0 you need ID and it is showing setting for Weak strength and Filter mode:
in code is named iconFilter1 you need ID and it is showing setting for Middle strength and Filter mode:
in code is named iconFilter2 ID is needed and it is showing setting for Strong coffee and Filter mode:
in code is named iconGrind0 ID is needed and it is showing setting for Weak coffee and Grind mode:
in code is named iconGrind1 Id is needed and it is showing setting for Medium coffee and Grind mode:
and the last one is named in code iconGrind2 Id needed and is showing setting for Strong coffee and Grind mode:
How to get icon ID is explained many times here on forum so I will skip that. After you get ID of all icons then you need to replace them in main loop and for buttons Brew, Keep warm, Weak, Medium, Strong, Change mode, Reset machine and main loop. Code is well commented and looks like this:
-- VD ICONS ----------------------------------------------------
-- enter ID numbers of corresponding icons on your system
local iconBrewing  = 1041;
local iconWarming  = 1042;
local iconNoCarafe = 1044;
local iconFilter0  = 1045;
local iconFilter1  = 1046;
local iconFilter2  = 1047;
local iconGrind0   = 1048;
local iconGrind1   = 1049;
local iconGrind2   = 1050;
local iconLoWater  = 1051;
local iconNoWater  = 1052;
And before you can start enjoying your coffee there is one more touch that needs to be done. You need to go to main loop code and first setup smart plug ID. Look for this code in main loop:
-- SMART PLUG --------------------------------------------------
-- enter ID nuber of smart plug to which Smarter cofee is
-- connected. Smart plug is the only way to check machine status
-- at the present moment so it is needed for proper functioning
-- of this VD
local plugID       = 135;
Then if you want to be notified by VD when coffee is ready then find this code and enter ID of your mobile devices to which will be send. You can put as many as you like between brackets {} just separate them by comma eg. {2, 45, 121}:
-- PUSH NOTIFICATIONS ------------------------------------------
-- define users that will receive push notifications when
-- coffee is ready if leaved empty no notification will be send
local userID   = {}
-- enter default flags: 1 - will send, 0 - will not send
-- must be same number of flas as users
local userFlag = {};
-- enter push message text that will be sent when coffee is
-- ready
local pushMessage = "Coffee is ready!"
-- here you can put code that will change flags to whom push
-- notification will be sent
function setupUsers()
  -- here you can put code to dynamically change which users
  -- will get push notifications if you use flags
If you want to change who will receive push notifications you can use variable userFlag for that. For each userID you can enter 1 to send push notification or 0 not to send. Then you can add some code in function setupUsers() where you can change flags as you wish. For example I use that code to stop receiving push notifications when I'm away from home. If you don't need this feature then just leave brackets empty. And of course you can change message for pushMessage to your language.
And if you want to completely translate VD to your language you just need to check all code for this part:
-- MESSAGES ----------------------------------------------------
-- enter messages in your language
-- response messages from coffee machine
local _respBrewing  = "Brewing";
local _respAlready  = "Already brewing";
local _respInvalid  = "Invalid argument";
local _respNocarafe = "No carafe"
local _respNowater  = "No water";
local _respLowater  = "Low water";
local _respResetOK  = "Reset OK";
local _respCheck    = "Check machine";
local _respFailed   = "Transfer failed";
-- command sent by this button
local _command      = "Brew";
-- coffee machine status messages
local _statReady    = "Ready";
local _statNotready = "Not ready - fill in coffee";
local _statBrewing  = "Already brewing!";
local _statWarming  = "Warming coffee!";
local _statFaulty   = "Faulty - check machine";
local _statNocarafe = "No carafe - put it back";
local _statLowater  = "Warning! - Low water";
local _statNowater  = "No water - fill tank";
I try to make it easier for you as much as I could in this four days of development so all messages I collected on beginning of the code. Some buttons have more messages, some don't so you better check them all.
At the end just short explanation how it works. Before first run, you will need to check if settings in VD corresponds to machine settings by checking display on the machine or original app. When this is synced you can start using it.
Before first brewing status of VD must be Ready. If it is not you can press button Reset status to just reset VD or Reset machine to reset all to factory settings. Reseting machine will clear all default settings so you will need to send them again by pressing button Set above as default after you make your favorite choice of strength, cups and mode. This default settings will be always set back after brewing coffee no matter what settings was for the last brew. After brewing coffee status of the VD will be always set to Not ready except if there is No carafe in place, or No water or Low water. After rectifying cause: placing carafe in place, filling water and cleaning filter you will need to press button Reset status to put it back into Ready state. If this is too annoying you can always setup some short scene that you will trigger with some switch, button or swipe or whatever and reset VD to Ready status. If you want to keep coffee warm after brewing you can do that by setting time and then pressing button Set above as default so warming will start immediately after brewing, or you can setup time and then press button Keep warm. If during Keep warm you press button Keep warm again this will stop warming but only with new machine firmware. Keep warming time can be set up to 40 minutes. And that's it!
Enjoy coding and coffee!!! :-)
EDIT
Still working on 4.180
 Share
