Netatmo Weather Station suite standalone 3.4
   (4 reviews)
Netatmo Weather Station suite standalone v3.4
INTRODUCTION
Netatmo Weather station suite brings complete integration of Netatmo weather station to HC2 users including rain and wind gauges and support for more than one station.
PREREQUISITES
  • Fibaro Home Center 2 with firmware 4.160 or greater
  • Sankotronic Lab. Emoji VD standalone (not required since v3.4)
  • Netatmo Weather station
FEATURES
  • Complete integration of Netatmo weather station with HC2 including rain gauge and anemometer
  • Support for multiple Netatmo weather stations
  • Support for maximum 3 additional indoor modules
  • Smart update system that follows Netatmo weather station cloud updates
  • Completely independent installation does not require any more Weather State VD or Main scene FTBE
  • Netatmo weather station measurements can be shown on Weather State VD and HC2 web GUI and mobile applications by means of Weather State VD and Weather
    provider plugin
  • VD has built in multi-language support with 27 languages included (see APPENDIX 1 for the list). VD can use HC selected language or user can select any other available
    language.
  • Easy setup for VD icons (on UHASTM compatible version is this even easier)
  • Global variables are automatically added, monitored and repaired and does not require user intervention
INSTALLATION
Please check provided User Manual and video from @MarcoTorino71:
PACKAGE CONTENT
  • Netatmo Main module VD
  • Netatmo Outdoor module VD
  • Netatmo Additional indoor module VD
  • Netatmo Wind sensor VD
  • Netatmo Rain sensor VD
  • Netatmo Weather station scene
  • Set of icons for all VD's and scene
UPRADE PACKAGE CONTENT
  • Netatmo Main module VD main loop and update button new code
  • Netatmo Outdoor module VD main loop and update button new code
  • Netatmo Additional indoor module VD main loop and update button new code
  • Netatmo Wind sensor VD main loop and update button new code
  • Netatmo Rain sensor VD main loop and update button new code
NOTE - User manual is now provided as separate download.
TERMS AND CONDITIONS
DISCLAIMER
VERSION HISTORY
  • 3.4 - Scene code changed to use new Netatmo API grant access by replacing username and password with tokens. All VD's since v3.4 do not need Emoji VD to be installed to work properly.
  • 3.3.1 - Scene code changed to get rain amount for past 3 adn 6 hours to better support Irrigation Control VD. All VD's corrected some translations. Rain gauge VD changed labels content to display last 3 hours rain amount
  • 3.3 - Check below version description or consult User manual for more details
  • 3.2 - Corrected rain sensor code and cleaned some bugs in scene. Indoor modules corrected handling of CO2 measurement, improved updating code.
  • 3.0 – This new version is completely redesigned and made independent. Does not require Main scene FTBE and Weather State VD anymore. Updating is now synced with Netatmo cloud so readings are always up to date.
  • 2.0.2 – Code optimized and resolved some bugs
Here is look of the Netatmo Weather set:
Enjoy coding and your new Netatmo weather station suite! :-)
Sankotronic
Edited by Sankotronic
Uploaded new version 3.4
What's New in Version 3.4   See changelog
Changes in version 3.4
  • Scene code changed to use new Netatmo API grant access credentials with access and refresh tokens instead of username and password
  • All VD update buttons removed usage of Emoji database to work without needing to install Emoji VD
  • All VD main loops updated to reflect new version with minor corrections.
Upgrade instructions from any previous version to v3.4
  • Please download upgrade package: Netatmo Weather Station suite v3.4 standalone upgrade.zip
  • Paste new scene code over the old one. Reenter credentials and station MAC ID and save. Manually runs scene at least once to save settings. Instructions how to get tokens you can find in user manual.
  • Paste new main loop code on all VD's. Reenter settings and save
  • Paste new Update button code on all VD's and save.
  • Like 21
  • Thanks 11
Ibie
   2 of 2 members found this review helpful 2 / 2 members
@michu25
Hi there, i think you dindt install "Emoji VD standalone 1.1" from Sankotronic.
This is why your VD's look empty
I forgot to install it too ;-)
Link to review
MarkusG
   3 of 4 members found this review helpful 3 / 4 members
Hi Sankotronic,
I´m a fan of your VDs. Everything is very good explained, so that even i can use the VDs.
But right now i have got a question:
I would like to use Information of the global Variable "NetatmoWeather".
Right now i use this LUA code in a scene:
local nT = json.decode(fibaro:getGlobalValue("NetatmoWeather")) -- read global variable
local stationNo = 1  -- set station number
local d_Rain = wT.netatmo[stationNo].rain.day
fibaro:debug(d_Rain)
But in the debug is written:
[fatal] Unknown exeption: /opt/Fibaro/scenes/179.lua:10:attempt to index global `wT`(a nil value)
I would be very happy if you can help me, because i want to use this parameter to decide if i have to water the garden.
Thanks for your support
Response from the author:
Hi @MarkusG,
Thank you for the review.
Regarding the error in your code change this line of code:
to be like this:
local wT = json.decode(fibaro:getGlobalValue("NetatmoWeather")) -- read global variable
I checked user manual ant there is a typo in examples how to read values from global variable. Local variable is named nT and should be wT. Sorry for the inconvenience.
Link to review
CastorF1
   0 of 1 member found this review helpful 0 / 1 member
Hello
Great job
Unfortunately I have  a problem with several Netatmo Virtual device .Every  night  after  midnight  I receive  a Message from Fibaro with lua error for each Netatmo device for exampleGabinet (? ) [id: 682(7)]
[ ERROR ] 00:09:28: line 75: bad argument #4 to \\\\\\\'format\\\\\\\' (string expected, got nil)
I have the HC2 with last firmware
Thank you for your help
Link to review
loopez
Hello, setting up went ok but still I have error in main scene:
[DEBUG] 00:11:10: 2019-08-24 00:11:10.808135 [ fatal] Unknown exception: /opt/fibaro/scenes/8.lua:101: attempt to concatenate local 'room' (a nil value)
can you assist?
Hi @loopez,
Just move all devices from Unassigned room to some other room and error should not occur again. Thank you for reporting. Will correct that for next release.
Link to review
