fireball 0
Hi im new in this forum.
I bought a FIBARO RGBW Modul to manage my sprinklersystem. It works fine. I take the 4 Channels to "dim 0 or 99" each channel and so i manage each of my 4 valves.
But now... i want to add a rain-switch into my system. I put it to IN1 and if i switch it, i can shut on / off the R channel.
But i use the RGBW Modul in FHEM an have only the 4 outputs in my Code.
The mission is: I will read the status of switch , so i can choose in my code if its rain, then no sprinkler will work, if its dry, the my own code can manage the sprinklersystem.
But how can i get the state? Which configuration the RGBW Moduls is needed?!
I try FIBARO_RGB configInputsOutputsConfiguration: 39321 instead of standard... but it works like befor...
here my german topic in fhem;
THX 4 help
René
7 answers to this question
