Auto lock door when after door is closed (door sensor)
serrzy
Hello
I am trying to create a scene which will lock the door lock (lockwood door lock device 31) after the door has been closed for 5 seconds (Fibaro door sensor device 114).
LUA code is below - what am I doing wrong?
Thanks!
%% properties
114 armed
%% weather
%% events
%% globals
if(startSource["type"] == "other") then
    fibaro:call(31, "secure");
else
if (( tonumber(fibaro:getValue(114, "armed")) > 0 )) then
setTimeout(function()
local delayedCheck0 = false;
local tempDeviceState0, deviceLastModification0 = fibaro:get(114, "value");
if (( tonumber(fibaro:getValue(114, "armed")) > 0 ) and (os.time() - deviceLastModification0) >= 5) then
    delayedCheck0 = true;
if (
 ( delayedCheck0 == true )
or
then
end, 40000)
7 answers to this question
Hey @serrzy Here is an "inspiring piece of code" that can easily be morphed into a script that closes a lock after the door sensor has been closed for five seconds. I wrote this script for the teenagers in my house. It switches off the lights in their room after some period of no movement. See for yourself...
This should work:
%% properties
114 armed
%% weather
%% events
%% globals
if tonumber(fibaro:getValue(114, "value")) == 0  then
  fibaro:sleep(5000);
"114 armed" need to be chaged to "114 value" if you want to trigger scene by door state (open/closed).
  • Thanks all. The code below works!!
    Where is the best place to learn more about LUA?
    %% properties
    114 value
    %% weather
    %% events
    %% globals
      fibaro:sleep(30000);
    It's great - very thank You for this.
    I'm looking for ones more improvement.
    When I close the door, script wait 5 (or 30) seconds and close the door. Is it possible to if I open door second one before counter reaches 5 (or 30) seconds to break, and wait when I close door for more then 5 (or 30) second.
    Thanks Rafal
    Thanks Rafal
    Do you mean if you reopen the door to reset the time counter again? I managed to get it to work using this code (adapted from the motion activated lights provided by @
     - thanks!!)
    %% properties
    114 value
    31 value
    %% globals
    if (fibaro:countScenes()>1) then fibaro:abort(); end
    function debug(color, message)
        fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span"));
    -- VARIABLES
    local scene = 68 -- ID This scene
    local motion = 114 -- ID for Door sensor
    local switch = 31 -- ID Door lock
    local starttimer = 30; -- Time for delay
    local timer = (starttimer); -- Timer in scene
    -- Start loop
     repeat
     timer=timer-1;
     fibaro:sleep(1000);
         -- If door sensor is reopened, restart time again
         if (tonumber(fibaro:getValue(motion, "value"))) > 0 then
             timer=starttimer;
             debug("grey", "Door sensor open. Time started again");
     until (timer<1)
    -- Lock door
    fibaro:call(switch, "secure");
    debug("red", "Door locked");
