Block Scene
avigo
Hi, I'm new here and I do not know if this is the place ,I want
to Turn off the light when nobody is in the room  for 30 minutes.
By using FIBARO Motion Sensor.
Here is an example. This scene turn on the light if there is movement and turn it off again after 60 seconds. You can adjust the scene to your liking.
I have a similar scene with if motion is safe for 300 sec. I have set 5 instances. And scene not working. It says Too many instance, because it triggers even if there is movement in those 300 sec. again and again... I have set free_time on every day at 18:30 and Work_time on 08:00. The scene triggers all day and trying to start.
Edited by TOMAR Electronics
change image
