Problems connecting HC2+Dahua camera
Rilero
Hello everybody,
I am having really problems trying to connect my Dahua camera with my HC2. For me it is impossible.
I have received the right urls MPEG and jpg direct from Dahua support Hotline, but i am not able to see my cameras through the HC2.
Anyone can help me please????!!!
Thanks in advance
19 answers to this question
  • Hello,
    My urls:
    /cgi-bin/snapshot.cgi
    /cgi-bin/mjpg/video.cgi
    Saludos
    Ricardo
    Hi @Rilero here is the url i use for jpeg : cgi-bin/snapshot.cgi?channel=0. And the one for mjpeg : axis-cgi/mjpg/video.cgi?channel=0&subtype=1 maybe it will help you.
    Guest pablo77
    Just try this for jpg:               snapshot.cgi
    and for mjpg:                          video.cgi
    In my cam I'm not using long strings to jpg, like in the picture below.
  • @Pablo77 / @Tomy270570 ... thanks for your advice, but ... no Success  :/.
    I tried both urls and it doesn't work. @TomarElectronics was right, if I try my url with iOS, it works ... my problem is that I work with Android and Windows. Any other proposals?  Thanks
    No idea. Are you using a camera plugin or did you add the cam by the « add device menu » ?
    Edited by Tony270570
  • there is no plugin for Dahua Cameras.
    I use "add device" and i write direct all the cam configuration (IP, user, password, url jpeg, mjpg,, ...)
    I tried also to use other plugin, hoping that maybe they could support my camera, but it doesn't work.
    Yes i know there is no dahua plugin but there a generic on, i’ve also used this before before to came back to the add device.
    i had a look here :
    But it only shows the 4430 and not the 4431. Don’t know if they are using the same urls. The 4430 is using the url i gave you.
    I’ve really no more idea, sorry. Hoppe you’ll find the solution!
    Dahua (latest firmwares and newer models) uses Digest authentication, which is not supported by Fibaro:
    Hi @Lambik thank you for your feedback, we have now a clear answer. And i know now that i’ll’not update my camera firmware (it was in my long to do list !)
    @Tony270570 Beware! Not updating camera firmware is not preferred, because of high security risk!
    Just wanted it to be mentioned....
    Yes @Lambik i know and you’re perfectly wright! But for this shot i’ll take the risk, the cam is used by the hc .Thank you again for the advise.
    You're welcome.  ;D
    If you don't update firmware, I suggest to block all camera access to/from the internet, to restrain some risks.
    • -2
    " to "
    Temat został przeniesiony z "
    " do "
