FIBARO temperature sensor FGMS-001 as room temperature sensor for HEAT CONTROLLER FGT-001?
marbe
Hello, I would like ask if is possible use FIBARO temperature and motion sensor FGMS-001 as temperature sensor for FIBARO THE HEAT CONTROLLER  RADIATOR THERMOSTAT FGT-001?
I know that heat controller has his own Bluetooth temperature sensor, but if I have at room FGMS-001 and I can set it to measure and send room temperature every 10 minutes via Z-Wave, then this temperature can be sent to heat controller too?
4 answers to this question
Nope. Dedicated sensor only. Isn't your motion sensor too close to the ceiling? Did you happen to read my topic on the "external sensor"?
Edited by petergebruers
" to "
Temat został przeniesiony z "
" do "
  • Hello,
    can I ask for answer Fibaro and if some plans for future? Thank you
    This won't be possible in the foreseeable future.
