Showing results for tags '4.100'.
Found 4 results
  1. Hi, I have an issue on my HC2 box, I cannot create backups anymore. My drive shows disconnected and a checksum is not completing. Also after a reboot all lights go on and after approximately one hour it runs like normal. So rebooting the box is taking multiple hours to complete I am running on 4.100 and would like to upgrade due to a message on a few websites stating that there is a security breach in previous versions. Creating a backup triggers a new screen, flickers a brief moment and finishes without generating a backup image. I have contacted fibaro and they did check the HC2 remotely but they are not able to fix the issues. I need to ship the box to Poland! I read a few topics about the RMA because of faulty/corrupted recovery modules. Is there a local alternative ? Anybody who can share some experiences on the shipping to Poland ? To be honest, I cannot unplug the box since all my home lighting/cams/heating are managed via the HC2. This really makes me doubt about whether I should continue on a Fibaro setup..
  2. Hi, Just installed a remotec v1.2 on my HC2 running 4.100 NO TEMPLATE The release notes clearly show its supported Why does this []?
  3. Hi Folks, I have one email scene that seems to be intermittent. I don't think its the email service as I do periodically receive other emails I log events to a user defined global variable and then once per day email it out triggered when I set morning mode. This is the email scene that I call fro morning mode scene I have some extra debug code to see what may be happening and this morning the debug on line was #37 fibaro:debug(LogStr) This executed correctly as I can see the output but the email didn't send after that. BTW - The UpdateEventLog function is a generic function I use in many scenes to log something to the global variable any ideas welcome as to why the email is not executing the send - I am using FW 4.100 Thanks -f --[[ %% properties %% events %% globals --]] -- Configuration - Scene Info sceneName = "Dump and reset Event Log" sceneVersion = "1.0.1" -- Scene Description -- Configuration - Device IDs -- Validate Number of Scene Instance if (fibaro:countScenes()>1) then --fibaro:debug("stop scene") fibaro:abort() end function UpdateEventLog(eventStr) local currDate = (os.date("%b %d - %H:%M")) local updStr = (fibaro:getGlobal("Log_Event") .."".. currDate .." ".. eventStr .." \n") fibaro:setGlobal("Log_Event", updStr) end function SendClearEventLog() UpdateEventLog("\n \n .....closing Event Log.") fibaro:sleep(1000) local currDate = (os.date("%b %d - %H:%M")) local LogStr = fibaro:getGlobal("Log_Event") fibaro:sleep(1000) fibaro:debug(LogStr) fibaro:call(2, "sendEmail","Event Log",LogStr) fibaro:sleep(5000) fibaro:setGlobal("Log_Event", "") UpdateEventLog("\n Event Log started") end SendClearEventLog() -- End of Scene Execution fibaro:debug("Scene, " .. sceneName .. " v" .. sceneVersion .. " completed.")
  4. Hi all, I've juste updated my HCL to latest version 4.100. Trying to create a new block scene with as trigger an octan remote device configured with scene-activation. The scene can't be saved : I've the "rolling balls" forever... By looking deeper have seen that there are some javascripts errors : check.js?version=1474920480617:2 Uncaught TypeError: Cannot read property 'indexOf' of undefine The error comes from this part of the code (the red indexOf - sorry but the code is minified, so it's difficult to read or give any line number) : blablabla ... b.isTypeOf(remoteControllerClass)&&b.isInterfaceOf(centralSceneInterface)&&a.swipe.indexOf("keyId")!==-1)return triggersArray.swipe.push(a.id+" CentralSceneEvent "+a.swipe.replace("keyId","")) ... blablabla and the box is looping on the following URL : http://192.168.0.100/api/scenes/50/debugMessages Any help/workaround/fix would be really appreciated! Thanks.
