Showing results for tags '4.130'.
  1. I am running a fairly simple setup with some 20 switches/dimmers and about 20 scenes, really nothing fancy. All hardware is Fibaro. The system is freezing or crashing continuously, works fine for a few hours and then stops. I have not been able to find the root cause. Not an expert, but worked professionally with software for 20 years... Have read about poor quality releases and many bugs, but is what I experience specific for me or rather normal?
  2. Hello there, Till i write ticket to support i want to ask a community. First of all customer has HCL, so please no lua. Jest received info from a customer that notifications does not work on his iPhone 7. Do you experience same issue or is it working for you? Customer has set some push messages in Notification panel. He set some push on device status change (device configuration) and made some scenes for it. Those scenes were starting manually. Maybe there is topic regarding that and if is, please point me to it. But i do not want to "necrofile" old dead topic.
