Showing results for tags 'hc2 4.510'.
  1. Hello, Am a learner and currently practicing lua coding, i would like to know how to identify errors before i use the codes on HC2 . Am not really sure what am doing. Am worried i may Crush the system. For instance, can't identify the problem... (i was trying to tell the TVwallplug to detect if the TV is Off then Turn it On, and if TV is On then Turn it Off) i want to use it when running scenes. The TV has 1 Button for On/Off Hop to get help from here. Thank you
