Hi Everyone
v 2.6 now available for users that have the SMsgH installed
Three offerings - Please read below to see which is right for you
1) WWWAPI Monitor {v1.0} - New (Mar8th) - vd that monitors only availability of the internet with option for sonos-api device. (leverages Smart Message Hub {v1.0}
2) Network Device Monitor VD {v2.5} - vd that can monitor several + devices and has built-in alert notification options (pushover/pc2popup/hc2email/allinone)
or
3) Network Device Monitor VD {v2.6} - vd that can monitor several + devices and deigned to be used with the recently released Smart Message Hub {v1.0}
Regards
[Autofrank]
LAN Monitor / Network Device Monitor {v2.6} ------ to be used with Smart Message Hub {v 1.0}
Modified to to be used with Smart Message Hub
- Label check removed to simplify virtual device
4 simple steps to upgrade from v2.5 to v2.6
Import the new virtual device
Configure your SendMsg preferences
Copy your v2.5 jsonNetwork table to v 2.6 and set UpdateData to 'true'
Set UpdateData to 'false' and that's it !!
LAN Monitor / Network Device Monitor {v2.5} ------ has built in Notification Services
The main difference between 2.0 and 2.5 are the following
Virtual Device ONLY - ( no need for separate scene, table updates are now done through VD)
Global variable table is created automatically created for new users
Added HC2 Popup service as an extra notification option
The following features are still available
Individual LAN devices can be marked for Alert
Alert Notification options configurable for HC2 email (default), pushover, or ALLINONE (@jompa68)
One Alert will be received when device goes offline and another when it comes back online
Online/Offline status is captured in global table that can be used to trigger other events
Debug routine called vdCheck will verify that correct quantity of vd labels and format was setup
Status/Error/Check feedback through the virtual device log console as visible through the Web UI
I use this to monitor Internet, Unifi Security Gateway, HC2, Sonos API (pi), TV's, Sat Box, Apple TV, Droid Box, Alarm Panel, Alarm Gateway, Syn NAS Global cache device, Cameras, Tablets, Sonos players, Access points and phones. Alerts setup for Internet, USG, Sonos API, Access points, cameras, Sonos players, Alarm panel, alarm gateway and NAS. There are some nuances with some devices such as TV's and Phones.
Open Ports of some devices that were shared by users
Internet google (port 80)
Sonos players/zone (port 1400)
Sonos API (port 5005 or 5006)
Raspberry Pi Hosting API (port 22)
iPhone Port (port 62078)
Smarter coffee maker (port 2081)
Smarter iKittle (port 2081)
Philips TV 47PFL5000 (port 1925)
Foscam cameras (port 88)
NAS Netgear U6 (port 80)
Global cache GC100-12 (port 21)
Humax FoxSat satellite receiver(port 80)
Apple TV Gen 3 (port 5000)
NPET MXQ Pro TV Box - Android 5.1 (port 7002)
Sony TV’s (port 80)
Samsung TV (port 8080)
Synology NAs DS415Play (port 80)
SPC Gateway (port 80)
Siemens Alarm Panel (port 443)
HKVision IP Camera (port 80)
Unifi security Gateway (port 80)
Unifi UniFi AC LR Access Point (port 22)
Samsung Galaxy S6 / S7 (port 5060)
Samsung Tablet (port 5060)
Generic Android Tablets (port 5060)
Airport Express and Airport Extreme (port 5009)
Amazon Echo Dot and Fullsize Echo (port 4070)
== INSTALLATION: Upgrading from 2.0 ==
- Import the LAN Monitor 2.5 VD and copy in device table from Update Network Table 2.0
- Run VD with updateData = "true" to update the Network table (default setting is false)
- Run VD with updateData = "false" to operate in normal mode
- Update notification and frequency of update options
== INSTALLATION: First Time Users == STEP 1 - Import the LAN Monitor 2.5 virtual device
- Populate the device table. Device, ip, port and enter alert = "1" for device notification
- alert is user configurible per device
- alert = 1 (enable alerts - alerts sent if it goes offline or comes back online )
- alert = 0 (disable alerts for this device)
- Select the notification options
- Run VD with updateData = "true" to populate the device table
Step 2 (optional) - create labels to display device status in VD
- Create one label for each device in the global variable table, use the default ID - Label1, Label2, etc.
- Enter Label Names (1, 2, 3, etc) to match order order of devices in Table (devices can be skipped but ID's must match)
- Select Main label to display one device when observing through Web UI
- If you want to use all labels you can use Set vdCheck = "true" to confirm correct quantity and format of labels.
== FILES ==
Use the version if you don't have Smart Message Hub installed
>> Network device Monitor VD {v2.5} ------------> LAN_Monitor_2.5.vfib
Use this version if you HAVE Smart Message Hub installed
>> Network Device Monitor VD {v 2.6} -----------> LAN_Monitor_2.6.vfib
Thanks to @jompa68 , @petergebruers , @sonnyboy and @boerremk for their input
Regards
-f
