Showing results for tags 'registering device'.
  1. I’ve hard wired the LAN to my Fibaro Intercom. The app discovers it and as I get to the point of finishing the set up a screen appears that says “Registering the device this may take a while” after about 2 mins the system times out and I start all over again. I’ve tried doing this multiple times but I’m unable to get through this step. I’ve tried using the wireless network but the same happens. Obviously both the LAN and wireless network work. I’ve also tried setting the LAN manually and assigning a static IP but the same happened. Any ideas what I’m doing wrong?
