Showing results for tags 'script language'.
Note. The first ~2000 posts of this thread is mainly about EventRunner3 that is for the HC2. EventRunner3 is not developed further, but bugs are fixed as they are reported. For HC3, the version is EventRunner4, and is a QuickApp,. Here is a post introducing EventRunner4. Most of the 'Event Script" syntax and commands are still valid and old posts can be of use for new HC3 owners. Here is an example of how to code in a "single instance / event" style. A style I'm using today for all of my scenes. The idea is that instead of having to deal with a new instance being spa
I'm using a ZRC-90EU and everything works fine but I don't like the way I need to assign a action to a button (function). As you can see in the picture, in the Advanced page of the device you can assign an action to each button but you have to start from scratch every time (I can not assign an existing scene to a button).... With a block scene it is possible as well but if you want to assign 1 function/scene to one button and you know that every button has 4 options (1x,released, held and 2x) than I have to create 32 scenes.... I am new and have a HC3 so I never had HC2, HC
