Camera on FIBARO ... which model . recommendation ?
Guest ericf
Guest ericf
I would liek to connect a IP camera to my FIBARO but I want:
- to find a good one,
- on IP,
- fully supported on FIBARO or that could be manage with advanc eparameter
- be able to get photos/movies
- is there a possibility to save the images/movies on the FIBARO ?
Eric
10 answers to this question
Guest Anonymous
  • try foscam IP cameras they are full suported by fibaro also u can record movies on hdd in your PC or cellphone
    Guest Anonymous
  • try also Vivotek cameras.
    U can set notification in scenes. Than You can recive images from camera on your email trigered by an event or timer.
    btw
    most cameras that streams mjpg/jpg can be used in fibaro sytem.
    Guest ericf
  • Hi guys
    thanks for the help.
    I will check/analyse them.
    For outside camera what is your recommendation ?
    Guest Anonymous
  • also foscam -
    or something simullar
    Is anyone using the Vivotek IP8332? Good resolution for the price. How about the compatibility with the UI clients?
    Eventually, I want to hook it into the TV picture-in-picture upon doorbell ring, but I still haven't found a good way to achieve that. Probably have to involve some IR sender...
    /CQ
    I was going to say.. don't bother with Vivotek. Mine stopped working at about version 1.038 and has never worked since, not even on the Beta. I have an FD8361.
    Guest ygh
  • Hi,
    Some testing/integration of Foscam IP camera with the HC2 is available at www.ghafoor.org
    YG
    I have the following cam's all work fine with the HC2
    Axis Video server Q241
    Ycam
    Apexis
    Dericam
    Dericam, Foscam, Apexis are all the same..
    Thank you for all the input. @davedotnet: what were your problems? Have you created Bugzilla issues for them?
