Everspring ST814 Temperature / Humidity Detector
jasontodhunter
I have the unit successfully operating and triggering a fibaro relay module by means of linked devices and control panels. Good news!
1, I can set the parameters regarding Temp / Humidity thresholds using the parameters config option under advanced settings. Is the blue box supposed to show the current settings when you do this? At present I can only tell if parameters have been changed by going to the unit.
2, If I set thresholds for temperature manually on the unit can these thresholds report to the HC2 to trigger an event
7 answers to this question
Guest m.denysiewicz
could You send to forum screenshot with parameters?
I have also added the ST814 to the HC2 it's not showing any info.
How can i display the curent temperature via HC2?
Guest lunakk
You have to add this sensor 3 times
Thanks.. I stopped by the second try.
This need to be done for all the battery powered modules?
Guest lunakk
Only for ST814
Upadte:
Adding ST814 works only via the Web interface(3 times)
Adding via de HC2 button will not work.
The ST814 is still not working.
The device looks okay in HC2..but no update.
any tips?
