Zwave device distances
Guest Kuuno
Guest Kuuno
How far have you set up your devices or modules? I found somewhere that min distance should be 30cm, what happens when put closer? The topology gets mixed up...?
Thanks!
5 answers to this question
Guest KubaW
  • I squeezed two dimmers under one 2-gang switch. No issues, but the switch gets a bit warm sometimes
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />.
    This is of course extreme situation, but still - it works. The same goes for series of swithes - modules are definately closer then 30 cm.
    I care about antennas - I actually twist them into loose circles and rest them on the module or around inner wall, so they won't touch metal frame of the switch.
    Guest Kuuno
  • Ok, and so far you have not had problems with communication?
    Guest mhn
  • I have Innovus Smartdimmers placed side by side in the far end of my network. I installed them in 2007. So far no problem.
    Regards
    Morten
    Guest Kuuno
  • great, that opens few good ideas for me:)
    thanks!
