Remote Acces problem? Check Your DNS!
K.Bergmann
Ladies and Gentlemen,
Because of that, from time to time we get questions about remote access, I would like to outline some issues and ideas.
In the case of network configuration control panel, please pay attention to the DNS servers. Sometimes the customers enter the wrong DNS server address and because of that, remote access (via dom.fibaro.com / home.fibaro.com) will not work. (displays a white page after logging into the remote access panel). Personally, I recommend always set the address for DNS GOOGLE: 8.8.8.8 - with this address there should not be any problems with remote access. I would add that all the unit with software version from 1.027 automatically set secondary DNS google. Therefore, a potential problem relates only to HC2 with older versions of software. Please remember, if possible, to HC2 has always the latest version of software!
How to set the new DNS address?
To set a new address, go to Configuration tab and LAN Settings:
If we have data assigned from a DHCP server, change the type of network connection to a static IP address (DHCP data will be stored).
In the next step, we change the DNS address to: 8.8.8.8
Click Save!
If you have a problem with remote access, when you will change DNS, please restart Your HC2.
Edited by I.Srodka
Guest skeal
Sadly the screen stays white even after this change.
I have forwarded 80 and 22 to my hc2 and the direct connections do work (public-ip:80 in browser and public-ip:22 in putty for example) ...
where to look further?
i'd really like to have the beta versions...
  • Dear Members,
    For last few days we increased significantly capacity of our remote access server. If you still dealing with some Remote Access issues please reboot your Home Center 2. It will also reboot remote access software and after that it should works reliably.
    Hi i 'm a first time user!
    i just install the latest update for the HC2
    i made all the lan rooting with my french Free Box
    ip: 192.168.1.6
    sub: 255.255.255.0
    rout: 192.168.1.1
    dns: 212.27.40.241
    on the face of the HC2 only the Power is blue
    is it normal?
    on local everything working well even with the iphone
    but distant ins not working
    i'l try google dns 8.8.8.8 with no change
    Hello, If you installed BETA update 3.xxx then the remote access isn't working.. If you want to use everything as stable as possible, you should go back to 1.044 version..
    Guest deraaij
    1) Power off
    2) Hold Recovery button
    3) power on
    4) release Recovery button
    Mark
    Hi all
    I have remote access problems :->
    Fixed IP (LAN network) and 8.8.8.8 dor DNS IP Addeess
    I have a login error message when I try to connect to the HC2 notfrom my home
    It works when I'm at home (which is useless and confirm that my login is ok)
    Does anyone have an idea to fix this?
    /emoticons/default_icon_rolleyes.gif" alt=":roll:" />
    Remote access don't work with beta 3.xxx version yet!
  • Remote access don't work with beta 3.xxx version yet!
    Yes, it will be connected to beta in next updates.
  • Fabcatan,
    Doesn't it supposed to work for version 1.044 ?
    Home.fibaro.com works fine in 1.xxx version. It is just not available in beta yet.
    It worked only once for me in 1.044 version
    Since then I systematically have an error message as mentionned earlier
    HC2 with fixed IP and DNS 8.8.8.8
    Any suggestion to fix this would be welcome
    Thanks for your support
    I use port forwarding on my router (NAT). It works perfectly without using the "official remote access".
    I routed the external port 88 to internal port 80 on the IP address of my box.
    On the iPhone or on a browser I use the connection like this:
    I continue to have problems on two HC2, with both the 1040 version that with the previous version .... but sometimes it works, I think it's a problem with the server FIBARO and not with the configuration of HC2
    Hello
    Is there someone withinFibaro to check the acces logs and do some troubleshooting ?
    More and more I have the feelin that I've bought an expensive empty zwave box in a shiny envelop
    Except the compatibility with Fibaro sensors nothing is easy to get working
    Many teasers (ipad app, multisensor, power plugs, new features) and then ...... Nothing
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    Hi
    Is the remote acces via the Iphone app working yet? I have upgraded to 3.341 and mine isnt....
    thanks
    Don
    Guest jrkalf
    DonO, please check the changelog - Remote access is not available in beta!
    Partially agreed on that Krystian. I "sometimes" have it working on my iPhone through using 3G (no vpn or ipsec tunnels). odd, but pleasantly surprised.
    The webinterface for me is a 100% not-functional through the internet on beta. (as expected).
    Latest firmware..I can log in to my hc2 ,but there are not any devices listed,only my rooms are shown..
    Local access is OK,only remote web interface is not showing any device..
