K.Bergmann 2
Ladies and Gentlemen,
Because of that, from time to time we get questions about remote access, I would like to outline some issues and ideas.
In the case of network configuration control panel, please pay attention to the DNS servers. Sometimes the customers enter the wrong DNS server address and because of that, remote access (via dom.fibaro.com / home.fibaro.com) will not work. (displays a white page after logging into the remote access panel). Personally, I recommend always set the address for DNS GOOGLE: 8.8.8.8 - with this address there should not be any problems with remote access. I would add that all the unit with software version from 1.027 automatically set secondary DNS google. Therefore, a potential problem relates only to HC2 with older versions of software. Please remember, if possible, to HC2 has always the latest version of software!
How to set the new DNS address?
To set a new address, go to Configuration tab and LAN Settings:
If we have data assigned from a DHCP server, change the type of network connection to a static IP address (DHCP data will be stored).
In the next step, we change the DNS address to: 8.8.8.8
Click Save!
If you have a problem with remote access, when you will change DNS, please restart Your HC2.
Edited by I.SrodkaLink to comment
5
5
4
Jan 15
8
Jan 12
6
Dec 26
4
Dec 30
3
Fabcatan 5 posts
MrHaze 5 posts
K.Bergmann 5 posts
Igy 4 posts
Jan 15 2013
Jan 12 2016
Dec 26 2012
Dec 30 2014
KristianO
I Cant access my HC2 over home.fibaro.com any longer... Any other?
Rytis
Should 4.062 Beta work with home.fibaro.com or not? I have set static IP for HC2, point DNS to 8.8.8.8, restarted few times, but now success with home.fibaro.com...
60 answers to this question
