Danfoss living connect URGENT!
pewi
Hi i'am new at this.
I have purchased a HC2 and upgraded it to latest software, now to the problem.
I have 16 Danfoss termostats and it does not work. can it be wrong model on the thermostats, I have read that model 014G0002 with firware 3:02 does not work together with HC2
but all my termostats is found in HC2 but can not communicate ? I cant change the temp on the termostat.
Is their a update comming to resolv the problem ? Or do i need to buy new ones??
Please help
Br Per-Anders
5 answers to this question
Hi, what is the version of your danfoss LC ? I use the last model loaded with v2.5 and works well
/emoticons/default_icon_wink.gif" alt=";-)" /> I confirm that: 3.02 do not work with hc2 or other box on the market.
  • Hi and thanks for you promt reply
    I have model 014G0002 with firware 3:02, is Fibaro working to get this model to work with
    HC2 or do i need to buy new ones?
    Br Per-Anders
    It's not a good new for you...
    /emoticons/default_icon_sad.gif" alt=":-(" /> Your devices cannot work with HC2 !
    It's not the fault of fibaro because DLC v3.02 work only with Danfoss products with z-wave proprietary closed z-wave protocol. They do not work on another controller like Vera, EEDomus, Homeseer etc. No way, Fibaro cannot never supports this device with firmware 3.02.
    The new DLC z-wave device are in V2.5 Ref ending with 012
  • Hi Kirkroff
    That was not good new for me (expensiv) but i'am appreciate your help
    Br//Per-Anders
    The good ref is 014G0012 with firmware 2.5 (i use them and works well).
    /emoticons/default_icon_arrow.gif" alt=":arrow:" /> see this post for more informations:
    You can try to return the devices to your dealer if you have buy them for z-wave...
