Wi8 IM61 IP camera with HC2
Fabcatan
I'm trying to make my IP camera work with my HC2 ...... without success
I don't know which parameters to enter in order to have the mjepg video on the HC2 (the camera has both H264 and mjpeg)
Can someone please help me
10 answers to this question
Guest skyhooper
Hi
Take a look here
If your problem is not yet solved, just enter the following string in the 'MJPEG Stream Path' field:
goform/stream?cmd=get&channel=4
  • Hi
    Thanks for your messages
    I've tried different things
    Videostream.cgi
    none worked ...
    Guest GG
    HC2, from what I have discovered, only support JPEG-streams.
    means streaming video from secondary stream (I love chinese logic) so secondary stream in camera need to be configured to deliver JPEG.
    Here is a link to an english version of the http api (I think this will work for your camera, the parameters are the same as in the chinese document I downloaded from camera web site.
    Log on th web interface of camera and set secondary stream to JPEG
    Hope this helps you
    /emoticons/default_icon_razz.gif" alt=":-P" />
    Hi
    Videostream.cgi
    none worked ...
    I can confirm that this WORKS.
    Got 6 cams like this working really nice
    Try:
    Jpeg path: snapshot/view4.jpg
    Mjpeg stream: goform/stream?cmd=get&channel=4
    If you can give me remote access I can fix this for you
  • First Thanks to all of you
    I've applied the changes suggested by nmnetmedia
    Now I've got the pics
    , but still don't have the stream
    /Users/fabricecatan/Desktop/my wi8 settings.tiff
    /Users/fabricecatan/Desktop/my HC2 settings.tiff
    /Users/fabricecatan/Desktop/channel2.tiff
    Strange thing I've noticed regarding the stream, on some channels (i.e. 2) I've got a window for the video but not for others. Especialy channel 4, no video window.
    Note I use a Mac.
    I don't think it matters for mjpeg but just incase.
    If anyone has any other suggestion, I thank you in advance
  • the screenshots mentionned
  • problem fixed
    It works with the parameters from nmnetmedia, but not on Safari
    Ok with Firefox and Iphone
    Thanks again
    Guest lanshan75
    I have been annoyed by this problem for a long time,so thank you for your post, it is really useful for me.
    __________________________________
    share love,share happy,share useful information about
    and
