Aeotec 4-in-1 fully supported by now?
hvb83
I'm in need for some multisensors. Three of which should be able to be mounted in humid environments, so the new Fibaro sensors won't suffice anyway I think (if they ever get released..).
The Aeotec 4-in-1 would suit my needs, but afaik only temperature is supported by the HC2. Now I've got a webshop that says the sensor is fully supported from 1.036 and up. Is this true?
  • Answers 69
  • Created
  • Last Reply
not from my experience. It does seem to kind of work in the beta for me. Although periodically, all values show as zero. I think this is because I am using it in battery mode. Its made me want to power it via a usb connector, although that means fitting a new electrical socket near the top of the wall
Guest deraaij
I have the same experience. It finds all sensors in beta but drops occasionally (as described all values go to zero), after a while it picks them up again.
Mark
  • So if I do it on mains power, it might work? At least it's promising that all sensors seem to be found now... :->
    Guest hotrot_net
    I've got them on main power (5V USB connector) then they work fine.!
    Only one important thing, I had one that lost Icon's every now and then, after updating the firmware of the multisensor it's gone
    Keep in mind I use vers 3.424 HC2
    I tried both - 5V USB and batteries.. motion only works, others are zero constantly.. I also upgraded aeotec software but no change noticed..
    Lauri, wake up device in usb power you will get values after that
    Guest Kuuno
    i have tried that and does not work for me, i have 2 aeonlabs sensors!
    i tried changing the parameter 101 to 112 or 113 and that did not help
    the default value for them seems little odd, what should it be?
    Kuuno
    Kuuno, battery or usb power?
    only work usb power, add device and after 1 min wake up device it should get all values, and its working, slow but we can't do nothing about speed reaction
    Guest Kuuno
    i'm testing on power now but im having other issues after changing the values manually
    i have constant blinking of the light and unable to add/remove the device. seems like it went into some weird mode
    Guest hotrot_net
    my current values that are default BTW.
    [ Added: 2013-02-26, 17:02 ]
    A.Socha
    it is not slow. it works perfect on usb power.
    I did however setup polling every 180s. to update temp/hum/lux on the
    Scucciari, wake up device -> press 3 times on tamper
    Actually I cannot get it working also.. I have usb power and tried waking up several times... motion works, others are 0. Also I upgraded aeotec firmware..
    A.Socha, i've tried with 2 different devices, and despite pressing button 3 Times, does not work.
    Allowed it to work with usb power, I connect it to the wall with 2 meter USB cable?
    Guest b95_lun
    To me it seems to be an issue when the 4-1 sensor isn't in direct contact with HC2.
    It seems like it isn't using the mesh network.
    [ Added: 2013-03-10, 19:40 ]
    Disregard My last idea
    Now after some time both my sensors have stopped sending updates.
    Motion sensors are working for both but neither of the other sensors
    Guest hotrot_net
    I dont get updates form lux,temp, hum. after installing beta 3.488.!! sensor works fine.!
    This can't be a problem of the 4in1 because before the update it was working fine.!
    This seemed to be working for me on the beta, until the last 3.488 release. now it always reports 1000LUX, and 21.6c no matter what.
    I tried removing and re-adding, but it doesnt make any difference
