Basic Code Clips for LUA starters
robmac
To help those that are not familiar with LUA a starter library of clips that work in Fibaro.
Please add any you find useful.
  • Answers 151
  • Created
  • Last Reply
Guest dsilletti
look here
Hi, thank you for support, anyway in my case there are several commands to execute in every "if->then", my code seems OK, I don't understand where is the mistake, can you please help me understanding how to solve this issue?
regards
Domenico
[ Added: 2013-03-29, 14:51 ]
Ok, I solved removing all else, using only if conditions for the 3 rooms
dsilletti, for "elseif" you don't have "end" in proper LUA
like for "else" there is no "then"
Guest dsilletti
thanks, got it, I'm a newbie in LUA :->
Finally we can do a lot of things with LUA, but according to me, a special section is required to store all LUA scenes examples, most useful scripts, tips and tricks sent by Fibaro Team and users.
Regards
Domenico
Here is a scene to check if there are more then 1 instance of any scene running.
If there are more then 1 instances it will try to kill it and start again (unfortunately killScenes not working in 3.517 - send to Bug tracker)
It's important, as if you start the same scene many times accidentally or with the other scene at the end it may lock your HC. I hope it's helpful.
Refresh nightTime global variable every 60 sec.
Problem with that is the HC2 don't have meteo in direct. For me HC2 refresh too late, i have the moon 1after.
Guest jrkalf
jrkalf,
if you will write id_device =1 then you gonna rebulid for all devices (leave for night that will take few h)
id_devices >1 then only for that one device
for all devices
A nice piece of code from Fibaro for optimizing your network.
example of Scene activation for dimmer
change 507 for id your device
Open the gate for all guests coming for a party.
Here is a code that will automatically open the gate and turn on the lights for a specific time i.ex. 30 minutes after someone press the Bell ring. Very convenient when plenty of guests are coming at the same time.
In order for this to work the scene has to be "not active" otherwise it will always open the gate.Just before the party start the scene and during the preset time every guest will have the gate open after the ring. Make sure that the ring switch is active for more then 1 second or change the fibaro:sleep() parameter to lower.
"Dark" is a global variable set to 1 after sunset.
example virtual device who can control heating panel
In zone id 1 I want change temperature for Monday on 12
and here you got example for Holiday Mode
0 - turn off Holiday Mode
>0 turn on Holiday Mode and set that temperature
Ah this is great thanks!
Trying to build a thermostat for on the wall using a friendly arm... so this is great for that...
is there also a way to get the actual schedule of a room through json?
any way to control the alarm system? disarm / arm... with pincode? (using json)
A.Socha,
Super and want more
Hi All,
As a real newbie to LUA can someone point me in the right direction for more info in regards to coding for the HC2, for example in the following line of code:
fibaro:call(77, "turnOn")
“call” appears to be a valid option as well as “getvalue” and “debug”
Is there a more comprehensive list somewhere and how they relate to the HC2?
Also, “turnon” in the line above, is this predefined or is there a list that relates to HC2?
Thanks in advance for any help.
amilanov, you can inspect all device actions and properties when you are in LUA Mode
/emoticons/default_icon_biggrin.gif" alt=":-D" /> see screen capture below.
Ah, that almost feels like a Homer Simposon "Doh!"" moment. I'll have a play around with the interface before I ask anymore questions
/emoticons/default_icon_razz.gif" alt=":-P" />
Guest Charly
For security reasons it may be smart to not always switch the lights off at the same hour and minute a small addition can change the time every day. Here I have added the math.random function and made the switch off time random between 23:18 and 23:43
%% properties
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
while true do
local currentDate = os.date("*t");
if (
( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "23:" .. string.format("%02d",math.random(18,43))) )
then
fibaro:call(6, "turnOff");
fibaro:sleep(320000);
fibaro:call(4, "turnOff");
fibaro:sleep(60*1000);
else
if (
then
A wake up light that increases the dimlevel of the light in a given interval. You can change the settings in the beginning of the script.
%% autostart
%% properties
%% globals
while true do
local wakeuptime = "21:34"; -- time to wake up
local startlevel = 40; -- start dim level
local dimlevel;
local maxlevel = 100; -- max dim level
local diminterval = 1; -- interval time in minutes to wait to next dimlevel
local levelsteps = 20; -- steps in procent to increase dim level
local light = 21; -- light to control
local debug = true;
if (maxlevel > 100) then maxlevel = 100; end
if (startlevel > maxlevel) then startlevel = maxlevel; end
if ( ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == wakeuptime) ) )
then
fibaro:debug("Scene started at: " .. os.date());
for level = startlevel, maxlevel, levelsteps do
dimlevel = level;
if (dimlevel > 100) then dimlevel = 100; end
fibaro:call(light, "setValue", dimlevel);
if (debug) then fibaro:debug("Set dim level at: " .. os.date()); end
if (debug) then fibaro:debug("Dimlevel: " .. dimlevel); end
fibaro:sleep(diminterval*60*1000);
Remko
boerremk, take a look on my dawn simulator engine
Advanced WakeUpLight with one or more dimmable device and you can choose between several different transition curve
You're welcome.
Hi
I am trying to use your script as below
but every time I open the door I get 2-3 emails, as if the 30 minutes pause is not having any effect.. I'm running 3.548. What am I missing?
Thanks a lot
Riccardo
rcanetta,
Probably you have started a few instances of the same scene. Stop the scene and Add the following code at the beginning before 'while' :
I hope it helps.
