New scene with a motion detector
pewi
I'am trying to make a new scene in our bathroom
sample scene is only working for aprox 15sec (value in motion detector?)
My wish:
When movment is detected then the light comes on and closes
after 60 sec.
14 answers to this question
Here You have got the right one
  • Thanks Wasil
    /emoticons/default_icon_smile.gif" alt=":-)" /> one step forward..
    Guest dsilletti
    Hi all,
    this scene will turn off the light after 60s even if there is someone in the bathroom (and this is not a good thing in some moments, you need to move every 60s, after every swith off, to turn on light again
    /emoticons/default_icon_biggrin.gif" alt=":-D" /> )
    I was wondering if is possible to use a time variable that is increased of 60 sec every time a momement is detected (during the 60s countdown).
    So the timer will increase +60s, +60s all the time that a moment is detected, do you think is possible to do something like this?
    Regards
    Domenico
    Hi all,
    Regards
    Domenico
    I am not 100% sure, but I think it will work as You want to. Everytime motion detector is breached the scene will start and add +60s for Your lights. I will check it in 2 hours and give You answer.
  • Hi !
    I'am still having trouble with the scene
    I have done according to wasil with no luck.
    When i have saved and pressed run on the scene it works it's on for 60sec,according to scene.
    If I then move and the lights come on it turns off after approx 15 sec again ??
    What i'am i doing wrong??
    Pewi
    Guest hotrot_net
    I've got a more complex way
    1. it checks lux on a lux sensor has to be below 250 (outdoor sensor)
    2. a room detector checks if its breached.
    3. it checks if var "lichtauto" is set to 0 (day night option or whatever)
    4. then it set var "lichtauto" to 1
    5. it turns on the light
    6. it turns off the light after 600 sec
    7. it set var "lichtauto" to 0
    If got the same problem when there is movement detect in this run the light still turns of after 600 sec.!
    Guest dsilletti
    Probably we need 2 scenes, one that increase the duration time of +60 (probably with a variable that we can call Time) every time the sensor is breached, and one scene that switch on the light and shut off the light after time (Time).
    So in real time the variable Time will be increased, but the other scene need to access the variable during the execution...
    I don't know if is possible to enter a variable instead of a number in the shutdown red time box in Scene block editor (insted of enter AND LIGHT TURN OFF in 60 or 600, we need to enter AND LIGHT TURN OFF in Time at the end f the scene).
  • Hi
    i'am going crazy, i can't get the scene to work.. nothing is happening when motion is registred
    1. I have tried both with Associations and not (fibaro dimmer and motion detector)
    2. I use SP814 Motion detector
    3. SP814 registrate movement in HC2 but nothing is happening ¨
    4. I can not adjust Parameter 3 Sensitivity Level ? It is awake and transfering settings?
    Do i need to configurate the dimmer module and motion detector in any special way?
    Please help
  • Yes ! it is armed and i can see that it changes status in HC2
    Guest Lode
    Ok, i suggest you try something else first when the detector is triggered.
    Make a testsecene and instead of setting the light to turn on do something else.
    So you can be sure it's not the detector but the lamp.
    Did anyone got this working? I would like to use same functionality - auto on/off, but lights should be turned off only if there has not been movement about 5minutes (360sec).
    Guest shapa
    Hi
    I've got some very weird issues with "blocks" scenes (they are not working properly sometimes).
    Just switch to LUA and everything is fine.
    Probably, we need to open some critical bug report but I thought the issue is known.
    [ Added: 2013-05-11, 11:37 ]
    And please set "100" to the "turn on" block - sometimes it helps.
    [ Added: 2013-05-11, 11:38 ]
    Also, your software is old - upgrade to 3.548 - it is more stable (but far still far away from release quality)
