Samsung smart tv
dzaif
4 answers to this question
very unlikely on the ue??D8000 series had bluetooth power on support... so i would not hold your breath!
As discussed in other topics.
you can use a Fibaro switch for turning On/Off the power.
TV will turn on to the last used status wehen the power is back again.
Guest dsilletti
Otherwise buy 1 of this:
or the wireless version:
and you can control everything like with original TV remote control, via Virtual device in Fibaro HC2.
(with these hardware you can control everything that has an infrared remote control)
Regards
Domenico
  • Thank you very much for your response!!
    I have a SQ Blaster from my old home automation system.
    Can I use this SQ Blaster with my HC2?
    My TV is Samsung UE55D8000
    Thank you!!
