Delay in scene
Guest Lode
Guest Lode
I made a simple scene to turn a lamp on for one minute when a sensor (Fibaro universal binary sensor) is breached.
It works but after the sensor is breached it takes about 40 seconds before the lamp turns on.
I can't see what is wrong ....
8 answers to this question
Guest jrkalf
  • Not sure if it's the lua code, but I have the same with my push messages and e-mails for a "breached and armed" situation on my door sensors.
    I think there's something wrong in the underlying code. Perhaps the Fibaro Devs know?
    Guest deraaij
  • You can use this code:
    Guest Lode
  • I'm sorry but it doens't work ????
    In my scene in think the delay is caused by the fibaro:sleep(60*1000);
    When the scene is activated and Fibaro is in the middle of that sleeptime your command will not be executed until it comes out of sleep.
    Guest deraaij
    Correct, due to the time constaint it has an unnecessary loop. But the only works when it is triggerden by device 22 and it is after 23:01.
    Guest Lode
  • Hi Mark,
    Why can't i get your code running ?
    Guest deraaij
  • Hi Mark,
    What do you mean with you can't get it running?
    Guest Lode
  • It doens't work ....
    [ Added: 2013-03-31, 17:25 ]
    Oops......
    While i was testing this, the sensor was already breached.
    So to get the scene running the status of the sensor has to change from not breached to breached......makes sense of course, but i didn't know that.
    Thx for helping me out Mark.
    Guest deraaij
    Oops......
    You are welcome!
