cURL / WGET
TANE
I like to use my DVR software for triggering HC2 commands by motion.
Application can start a app
I like trigger some devices using cURL.
This is the result.
C:\curl>curl --user admin:pass
{"type":"ERROR","reason":"MISSING_PARAMETER","message":"name: missing required parameter"}name wordt niet herkend als een interne of externe opdracht, programma of batchbestand.
It’s not doing what i want..
Any tips?
8 answers to this question
curl -X PUT -d '{"name": "Test", "value": "122"}'
Try that
  • Pointed link is not working
    Do I need to change the name, Test, value 122?
    I have just changed the user:password
    result is?
    Guest deraaij
    Oups, my code was just an exemple.
    Yours is an example for setting variables, those can not be done using url's in a web browser (as it needs a put instead of get).
  • Thank you.
    That’s working fine...
    know the Windows limitation of launching applications inside applications..
  • This is working great.
    Camera app will trigger devices when there is movement detected in the selected area.
    Works better than a PIR since you can select the area and the sensitivity or just ignore short movements <1 second.
    I'm using DVR software Xeoma
    see my short dutch review about this app
