emariu 0
I found some LUA code for VERA that would run a scene only if the light level is below a user set threshold :
local LOW_LEVEL = 20 -- the light level threshold for night
local DEVICE_NO = 33 -- the light sensor device number
local LS_SID = "urn:micasaverde-com:serviceId:LightSensor1" -- the LightSensor service ID
local currentLevel = luup.variable_get (LS_SID, "CurrentLevel", DEVICE_NO) or 0
currentLevel = tonumber(currentLevel)
if currentLevel <= LOW_LEVEL then
return true
else
return false
Can someone tell me how can I implement this function for HC2?
10 answers to this question
