mclass 0
There have been repeated requests for HC2 support for this device, bugzilla posts and even a sample sent to Fibaro (thanks Johnny C in NZ).
Yes, you can use other IR devices (eg iTach) to learn and transmit IR codes, but the Remotec is pre-programmed with many popular A/C units and is battery powered. Simply installed with no wiring! Have been using these with Vera to great success for a year or so now.
+1 if you want HC2 support now!
/emoticons/default_icon_cool.gif" alt="8-)" />Link to comment
22
10
7
Jan 22
8
Aug 12
5
Aug 19
5
Aug 14
5
chaicka 22 posts
Momos 22 posts
m.roszak 10 posts
Mo19 7 posts
Jan 22 2016
Aug 12 2015
Aug 19 2015
Aug 14 2015
mclass
There have been repeated requests for HC2 support for this device, bugzilla posts and even a sample sent to Fibaro (thanks Johnny C in NZ). Yes, you can use other IR devices (eg iTach) to learn and t
dgcon
The parameters 27 values for DAIKIN are: 6 11 1 26 313 321 324 367 2 30 32 50 211 290 325 29 162 163 261 264 265 267 31 33 266 268 269 270 366 289 When you set the parameter 27 from your HC2 if t
Momos
Hi All, I bought 2 of these Remotec ZXT-120 to control some LG splits. To my surprise the inclusion process went smooth on batteries and i got 4 interfaces for each ZXT. On/.Off , temperature con
150 answers to this question
