Guest jpr105
I found a really interesting post here:
So I tried to arm or disarm the sound alarm of my Foscam from my HC2. This works perfectly using a first virtual device.
This virtual device set Foscam parameters as follow : "sounddetect_armed" to 1, "http" to 1 and "http_url" to the HTTP command to be send by the Foscam in case of sound detection. It also set a HC2 global variable "FI8910_SoundArmed" to 1.
The goal of the "http_url" is to send back a warning to the HC2 in case of sound detection. So, to get this alert I use a second virtual device who is planned to set a global variable "FI8910_SoundDetect" to 1.
Finally I can use a scene with this scenario : if "FI8910_SoundArmed" equal 1 and "FI8910_SoundDetect" equal 1 then send a push to my iPhone and set "FI8910_SoundDetect" value back to 0.
So let's try it :
- If I arm the alarm sound and send the following command manually thru Safari, it works perfectly ... I got a push on my iPhone directly from my HC2 through the scene described above. Here is the command :
this command simulates a button press of the second virtual module described above ... and so, set "FI8910_SoundDetect" to 1.
Now, what is the matter ?
... it doesnt work at all
- I tried another solution like sending this command thru a html file located on my server :
... it works thru Safari but not at all from the Foscam "http_url" parameter (http_url=http://192.168.10.30/hc2/sounddetect.html)
Now I am lost ... may be using the cURL syntaxe. But I am not confortable with PHP. I need help.
The french version of this post is here :
Thank you in advance for your help.
Regards - Jean-Paul
1 answer to this question
