IP cameras compatible with Fibaro - list
Guest sztywniak
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
Hi, the "rs" does not matter. Above is the URL of me. I just stood there as well.
There is no SnapShot synonymous, there then runs the video in high class.
Which browser do you use? It works with Chrome. Not with my Internet Explorer.
Did you create several users in the Reolink?
I had the problem that multiple devices with only 1 user (admin & 123456) synonymous only with a device, the picture went.
On 1/27/2019 at 10:22 PM, Braun-Tristan said:
Reolink 5MP High Quality
(integrate in FIBARO Marketplace)
Works perfect. Video quality 2560x1920
Reolink RLC-420 5MP
Integrate in HC2 & HC Lite
Model = Other Cameras
Name = Empty
Password = Empty
Protokol = http
IP = IP-Adresse (no port)
jpeg & mjpeg   (same Url)
http://ip-adresse/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=&user=admin&password=123456
Hook at mjpeg & Update 2 seconds
Encoding in Reolink software
Stream Type = Clear
Resolution = 2560x1920
Frame Rate = 25
Maximum bitrate = 6144
H.264 profiles = high
Hi, sorry that I am only now maile. Had a lot to do and was on vacation ...
Have not tested battery operated. sorry
still no luck with this one @Braun-Tristan
stream path is full url despite the fact that http and ip are in other fields .
I tried creating a new user but no difference
Correct ?
http://192.168.1.248/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=&user=admin&password=123456
this is my 7th camera on the HC2 but no others are reolink
4 hkvision, 1 reolink and 2 octopi for my 3d printers
All cameras are wired including this one
reolink phone and desktop app all working okay
If you put the above url into a browser, does it show a picture ?
browser is chrome
Edited by AutoFrank
Sorry to hijack this post for a question?
@AutoFrank
You said you have Hikvision camera’s connected to you Home Center. I have 5 Hikvision camera’s but there is one thing I can get to work. The send photo to user. No matter what I do I get no picture send. I receive all the other mails that HC send without issues only this thing won’t work.
I created the LUA scene, added the camera by choosing it from the list and clicked th sendphototouser and filled in my user id.
I don’t use a NVR but a Synology for recording.
I hope you know a solution because I’m struggeling with this for a while now.
Hi @kevin,
I have a scene that when my doorbell is pressed it will sent photo's from 4 different camera's / angles (also a Hikvision camera) to our 2 phones.
This is working ver well.
/monthly_2019_07/2040173517_Sendpictureatringing.png.18cef22c876deeacb941a51ea863048d.png" />
@AutoFrank
I use the following
jT.system.DrivewayCam - ID of camera
jT.users.frankgmail) - ID of user to send email photo to
2 minutes ago, kevin said:
@AutoFrank @TRicky
Sadly both didn't work. I get no errors or whatever but the mail isn't in my inbox.
could it be the ID of the use that you a sending it to
I think ID = 2 is the hc2 super user (ie the email address you use to login to the HC2)
Could you try that  ?
On 1/12/2019 at 9:43 PM, Braun-Tristan said:
I always use Reolink for my clients. Very good picture.
Hi @Braun-Tristan
I bought the RLC420 and I can see the pic through client app add phone app and these all use port 9000
I cannot get the webpage to display and I tried all the usual thinks plus more.. (reflashed cam, other posrt numbers, url with port , etc)
A zenmap scan shows that only port 9000 is open and nothing on 80, 443, etc
I'm in contact with reolink support but I'm not very hopeful and about to send back the camera for a refund
Have you seen this issue before ?
Hi what phone app are you using?  So far I have been able to integrate Reolink everywhere.  Can you access it via browser?
Hi!
Is there any cheap Chinese camera work with Fibaro? I'm not planing to spend a fortune on it :P  Anybody tried a camera from aliexpress? thanks
On 5/18/2019 at 9:56 PM, Braun-Tristan said:
I don´t know. I only work with Reolink Cameras
Hi
Did you succeed to integrate Argus 2 unto Fibaro as Reolink says
Reolink battery-powered cameras can’t work with third-party software since they will drain the battery quickly. Most third-party software does not have the battery management option that allows the camera to enter the power-saving sleep mode when no motion is detected, and some are not compatible with Reolink battery-powered cameras.
Therefore, we recommend you to access Reolink battery-powered cameras
@AutoFrank and @Braun-Tristan
Did you end up getting the Reolinks to work with the HC2? Looking at the 420, 422 and 423 they all use H.264 compression and I was of the impression that HC2 didn't support that?
Thanks,
Scott
On 13/1/2019 at 19:21, Braun-Tristan said:
Hola Dan, debido a que la cámara está la mayor parte del tiempo en espera, la batería dura aproximadamente 3-4 meses. Menos si se registra mucho. Pero dado que en la caja de la batería hay 4 * baterías, puede obtener grad que con más potencia. Cree que las baterías 123a están en él. Hasta ahora, no he probado este modelo si es integrable en Fibaro. Pedí la cámara + panel solar. Piensa que son 1-2 semanas, entonces puedo darte más información.
Hello, I have two argus eco cameras with solar cell, I have tried to integrate them without success in hcl with the configuration that you have published, do you know if it would be possible to integrate them?
Hello all,
First post in the forum for me.
Does anybody know if Burg Wachter 304 Bullet camera can be added to HC2?
On their site I'm directed to SANTEC knowledge base where there are JPG and MJPG url's but I have no success in obtaining picture...
Any info would be welcome!
LILIN LD2222   OK
JPEG  snap
MJPEG  getimage?camera=0&fmt=vga
Fibaro works fine with AVTECH DGM1105QS and DGM1104QS.
See config / stream sintaxis here
On 4/16/2018 at 11:13 AM, Hellisloose said:
Will Foscam E1 work with HC2?
Any answer to this questions?
i'm trying to setup a Sunba 601-D20X (the h264 model) within Fibaro HCL (4.600).
According to Sunba support page you can get at least a snapshot picture with these options:
I was succesfully by getting a snapshot via a browser with this url:
http://10.0.0.210:8686/webcapture.jpg?command=snap&channel=1&user=user&password=password
However i never got an image in my Fibaro App or via the webgui.
I tried the following options:
First try:
Camera Model: other
User: <emtpy>
password: <empty>
protocol: http
IP: 10.0.0.210:8686
JPG URL: webcapture.jpg?command=snap&channel=1&user=user&password=password
Ticked option JPG, refresh 3 seconds
Second try:
Camera Model: other
User: user
password: password
protocol: http
IP: 10.0.0.210:8686
Any idea why this does not work?
Was anybody successful by implementing a Sunba Cam?
Best regards
Martin
