To light the lamp with lua code
Guest nohed
Guest nohed
if you want to turn on or off multiple lights with a lua code how should the code look like then
1 answer to this question
ID should be changed into the id of the device you want to turn on. For each device you want to turn on, you should add a line with the deviceID.
If you want to turn them off, you should change turnOn into turnOff.
