SUPPORT FOR ZIPATO MINI KEYPAD RFID/Z-WAVE
candrea77
Dear Fibaro,
can I know if the device ZIPATO MINI KEYPAD RFID/Z-WAVE is supported or plan to be supported in V 4.0
I need a device to arm/disarm my Fibaro Alarm ......... RFID seems to be OK, and the ability to use either rfid or manual code is great.
Please let me know , i need to know before buy
The device is actually from Benext. But they put their sticker on it. For support and manual, best take a look at Benext website. Currently it does not work as far as I know. But I am quite interested indeed if this is, can or will be supported?
  • Fibaro say :
    Dear Sir,
    Unfortunately, Zipato Mini Keypad RFiD/Z-Wave isn’t supported by Fibaro system.
    This device is not compatible with the our main controller (HC2 or HCL).
    Unfortunately, we never tested Zipato Mini Keypad RFiD/Z-Wave on V 4.0 our software.
    I don’t recommend you using this device with our system. This may not work.
    Best regards
    So for the moment the status is "not tested / not supported"
    Hope Fibaro can test this device ASAP or create a Fibaro device like that !!!!
    If I can suggest, you can migrate your system to a more cheap, versatile and "open" system, like Domoticz, if you want use the Zipato Mini Keypad and other zwave hardware not supported by Fibaro system.
    Kind regards
    i tested ZIPATO MINI KEYPAD RFID/Z-WAVE (Benext tag reader) on firmware V4.024b.
    It's now reconized like a door lock but it doesn't work.
    I did not have much luck with the Benext tag reader. Not with Fibaro but also not with domotiga and open-zwave. I bought
    instead and works like a charm
    which one works with hc2?
    benext version or the zipato version?
    They are the same and both don't work.. I bought an other one (see link above) that does work.
    i have the same... will have a play later! been sat in the draw for 6 months!
    yup! works fine bit of a tacky solution and would require the use of variables etc... but it works but it should as its a fibaro product after all
    I too, would like this to work on the Fibaro Home Center. There is an older thread covering this topic:
    This is what j.nowacki said 2014-11-24:
    "We have not tested such device and therefore can nor assure you it works with. I will try to get such device for tests but it will be a while until we integrate it."
    I have domoticz with a z-stick as well, and the keypad is reported to work, but I haven't tried it (because I'm trying to stick to one controller. I am mainly using domoticz to enhance the Home Center Lite's functionality, wake up dead node's and check that all scene actions actually are executed). The procedure for domoticz is documented here:
    I bought
    Bypassing this is as easy as knocking the device off the wall / removing panel and connecting two wires together?
    I have just ordered one... Let you know Thursday! But I have 3rd party controllers on standby!
    [ Added: 2015-01-16, 20:23 ]
    Until official support exists...
    Hi Fibaro,
    Can you please update If there is a change in status of the FRID.
    Thx
    I found a way to set the status "away" with a User-PIN and to set the status "home" with a RFID-Tag
    Please share
    It's a VD. But it stops working after 2 hours. Don't know why
    /emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> maybe someone have a smiliar issue with another vd which reads a json-response...
    Edit:
    I put the code in a button and made a scene, which push the button every 2 sec. Seems to work.
    I added it to the bugzilla:
    So far i'm using this code:
    First I created 2 variables: AlarmRfidStatus and AlarmStatus
    AlarmRfidStatus:
    1,2,3
    1 is if the RFID tag is scanned
    2 is if the number is entered on the keypad
    3 is if there is no number or its not recognized.
    AlarmStatus:
    Arm
    Armed
    Arming
    Disarm
    Disarmed
    Second: A virtual device. Then a button with the following code:
    (Thanks to boomx for sharing his code for inspiration...)
    Now I create 2 scenes with the following lua code:
    Scene: Alarm RFID check
    Next
    Scene: Alarm Arm check
    The code is only for testing, but it seems to work just fine. Basically it works this way: You disarm the alarm system with the code Home + 141 + OK and you can arm the system with the RFID brick.
    I haven't been able to find the Home or Away code inside the information that is sent to the Fibaro system ( device api page both master and slave... ). I tried and copy the data when using the HOME key and AWAY key and then the RFID, but when comparing the data side by side in a tool like WinDiff, nothing changed.
    Maybe someone knows how to find that?
    There is no different between home/away in the api
