fergalmccarthy 5
I have a number of smoke sensors, one in particular that is about 6 feet from the HC2 beeps intermittently. The HC2 is not reporting a low battery so I can only assume its Z-Wave connectivity issue. The smoke sensor is not marked as dead nor are there any Z Wave issues in diagnostics.
When will the HC2 log that this is an issue in the event log. If nobody is there to hear the beep, how are you ever meant to know there is an issue ?
11 answers to this question
