danalock
Guest nohed
Guest nohed
does anyone know if Hc2 in vertion 4 .. has support for danalock
11 answers to this question
Guest vipernor
    not supported, I'm afraid. There might be a small hope in there next version though. I am still waiting for the older polylock/polypad to be supported myself.
    Write to me or
    I dont see any plugin or luna with your link?
    You need only dsnalock and hc2 without any plugin or lua. Just add lock to hc2.
    How did it end with your Danalock. My lock will include but not respond to anything or show status
    I have danalock working fine. You have to add it then wake it to make it work properly. Took few tries and I had a few inclusions where it added but would not respond. I had to reset it, remove it from HC2 and remove batters for a min or so to allow another include. (i just pulled up the battery contact for a min or so).
    Guest vipernor
    This is good news, thank you for the information. Maybe there is hope after all. I'll assume you only have on/off functionality here?
    Guest vipernor
    Have anyone successfully included the Polypad together with the Polylock or Danalock?
