LUA scripts not scheduled
Guest erkadevil
Guest erkadevil
My LUA-scenes are not being rescheduled on Home center 2. They run once when I click "start" or "run" but never runs again.
This has worked fine before and just seem to have stopped working all of a sudden.
Even if I create a new scene with just at debug printout, nothing happens more than once.
It might be related to a firmware upgrade, I'm not what version of the firmware that this was running properly on. Now I use the latest version (4.042).
Any clues to what's going on and how I can get things going again?
BR
Erik
17 answers to this question
BR
Erik
I you post the script code maybe we can help you ......
Guest erkadevil
  • I you post the script code maybe we can help you ......
    Even if I just write a short script with a debug printout it won't run repeatedly.
    But one script that has worked is shown below (It is supposed to set a variable for light condition).
    Edited by erkadevil
    Use code tags, it makes code more readable
    post your script that doesn't run.....
    the one you posted above will be triggered by a device with id 12, how do you let the scene trigger that doesn't run??
    cheers
    emiel
    I'm new to Fibaro, bought HC2 and having some problems with scenes, works sometimes, sometimes don't work... don't get it.
    I'm also using FW 4.042, and have this script that sets the Variable 'Dia_Noite' = Noite, everyday 60m before sunset, but it's not working :/
    Here's the lua script:
    Do you know why this variable was not set?
    Thanks.
    @erkadevil, what is the device with id 12?
    @Morcegolas, I cleaned it up a little bit, put some debugs inside to make sure it runes properly, you can also print those times you are checking.
    Hi
    Able to enlighten me for your scene, which is the trigger function? and what does the autostart means? Is this scene running infinite?
    autostart means that scene will be run at the boot up of gateway (also when saved for example), there is no trigger, because there is infinite loop (tempFunc runs itself in some time - setTimeout function).
    @j.nowacki, with your scene it worked, at least the first time, now I'll ask you to do the same but instead of some time after or before the sunset I want to do at exact time 22:00H and variable is set do 'Discreto'
    This is my script made with blocks:
    The only thing I think its strange it's that I created this simple scenes with blocks and they should work, but they don't. :/
    Already tried to change to this but it don't work:
    All you need to do is change this 'if' instruction:
    just change the hour you are waiting for (e.g. '22:00' ) and the line where variable is being set.
    I did this but it didn't worked:
    You basically checked something like this:  if (current time == current time == 22:00) - do you see the problem here?
    Just try:
    if os.date("%H:%M", os.time() ) ==  "22:00" then
    OK, got it. Sorry but I'm really new to this. I'll do some search in how to programming in lua.
    I didn't know that:
    and:
    string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min)
    was the same ( current time ).
    But it's strange that with second option its not working, for people like me that are starting, the blocks is much easier,( I already realised that it's way more limited ) but that way was not working. Now I have try some times and its working (Y).
    So maybe there's a bug with blocks in FW4.042 I don't know. :/
    Thanks for helping out!
    I have 3 scenes to control this Variable, I deactivated them and add one with equal to the ones you told me only changing the if condition, it seams to be working, should I change anything or is it ok like this?
    Thanks.
    Does the infinite loop eat up the ram usage by alot? From your timeout of 60 * 1000 which is 60 seconds. Is this the recommended timeout for HC2 to operate normally?
    This is the advantage of setTimeout() over fibaro:sleep(), it does not consume any additional resources, so it is safer to use setTimeout() even with few seconds of delay, than putting scene to sleep.
    @Morcegolas it seems all right for me, let me know if something is not working as expected.
    Guest erkadevil
    Hmm ok, I guess that I wasn't really sure about the syntax here.
    So what you say is that putting the line
    "12 value"
    at the top will make the scene trigger on device ID12?
    /Erik
