Patatah
Hello
i have an itach ip to IR and trying to get codes for volume + and volume - for my denon 2310.
The code works fine when i test it from the learner window but when i copy/paste into the HCL's interface it does not.
ON/OFF function works perfectly from my HCL.
Any idea what the problem might be?
thanks
10 answers to this question
  • yes i did. on and off is working fine.
    i havent managed to get the volume working.
    has anyone else got it working on denon?
  • Heres an export of the virtual device. Still cant get volume to work.
    any ideas anyone?
    Code looks fine for me, but we do not have this device to test it. Do you see diode on Global Cache flickering when sending codes?
  • no. not for the volume button. just for on/off which works fine.
    Hey,
    I just took a look at your virtual device. Recently I did a few projects on iTach as well so I believe i do have the experience.
    Looking at your ON/OFF/+/- IR codes, your On codes looks a little longer than the rest. But you said ON/OFF was working fine.
    Judging from your OFF code, this should be the format of all your IR button codes. - Button has the correct format code starting with 38580 and ending with 38580.
    But for + Button started and ended with 38461. I suggest you might want to try to learn the code again as I believe that most of the codes are of the same format.
    I've did it for 1x Samsung TV, 2x LG TV, 5x Mitsubishi Aircon, 1x Sanyo Aircon.
  • Thanks for the tips MalvinYNJ I give it a shot.
    I tried the code in itach learner and it works fine j.nowacki. All i do is copy/paste to fibaro and addition the x0x at the end. still it doesnt work !
  • After learning the code in itach 20 times.. it finally works!
    thanks for your assistance
    and
