rajp 14
Hi there. I am running 4.047 on my HC2. I am trying to use this command in LUA to see if there is rain forecast and if I have already set the rain delay to 24 hours then ignore the step. However it does not like the FHttp line.. What am I doing wrong?? The statement seems to work in a virtual device but not in a LUA scene. The error I get is
[ERROR] 22:22:46: line 11: attempt to index global 'Net' (a nil value)
local sourceTrigger = fibaro:getSourceTrigger();
-- Set authentication
HC2 = Net.FHttp("192.168.1.xxx",80)
HC2:setBasicAuthentication("admin", "password")
-- get data table from the Sprinklers Panel
response ,status, errorCode = HC2:GET("/api/panels/drenchers");
jsonTable = json.decode(response);
fibaro:debug('Rain Delay Value: ' ..jsonTable.rainDelay);
I even tried the following.
local HC2 = Net.FHttp("127.0.0.1", 11111);
local response ,status, errorCode = HC2:GET("/api/panels/drenchers");
local jsonTable = json.decode(response);
still no joy.
This is my entire code.
%% autostart
%% properties
3 WeatherConditionConverted
%% globals
function tempFunc()
if ( ( fibaro:getValue(3, "WeatherConditionConverted") == "rain" ) or ( fibaro:getValue(3, "WeatherConditionConverted") == "storm" )
and (string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "12:01")
and ( tonumber(jsonTable.rainDelay == 0 ) ) ) then
fibaro:call(319, "pressButton", "2");
fibaro:call(tonumber(fibaro:getGlobalValue("RajIphone")), 'sendPush', 'Sprinkler Delayed by 24 hours');
fibaro:call(2, "sendEmail", "Sprinkler Delay", "Sprinkler Delay by 24 hours");
setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
tempFunc()
else
if (
startSource["type"] == "other" and ( tonumber(jsonTable.rainDelay == 0 ) )
then
