Mitsubishi AC over wifi (MELCloud)
alafauci
Hi all,
I'm almost ready to buy the MSZ-EF25VEW AC unit with the WiFI module. Now, since it will have an IP in the internal network, is there any chance I can use the HCL to control it?
Cheers,
ALF
interesting. i have been looking for a solution for my mitsubishi zens for a while now. please tell me how you go.
so far I've found this:
I now just need an hour or two to dig into it:
edit: also found this which looks like a means for turning the heating and cooling on/off which I guess you could use a fibaro relay to control (although I'd need to do a bit more research to understand how it works first):
Guest Zubadan
Any updates? I have a Mitsubishi Ecodan, and I am thinking of buying the wifi adapter, but only in case I can integrate this in my HC2.
On the Domoticz forum someone managed to control his Mitsubishi airconditioning with a Perl script:
Probably we can use the basics of this script to integrate this in our HC2.
I used the information
 with some extension to build an homebridge plugin for
Together with the homebridge plugin for
 I have complete control on iOS, also with Siri support.
I started to develop an Home Center plugin for melcloud but Fibaro is not currently supporting custom plugin for Home Center.
Guest Zubadan
A Melcloud plugin would be highly appreciated. Keep up the good work.
Anyone able to help with integrating a Mitsibushi wifi aircon to Fibaro via a virtual device?
Hi, I have the same question, I have set up home assistant and found melcloud integration.. maybe there is a possibility to let fibaro control the HA with melcloud integration ... ?
Unfortunately I am also following. I have 4 heat pumps controlled with the melcloud app.. Would like HC2 to manage the units.
I have reverse engineered the melcloud API but I don’t have time to write a complicated VD for melcloud and I also don’t have sufficient knowledge in writing Lua VDs. So if there is someone with the required knowledge and free time I can assist him with the API communication.
