HCL freeze with aeotec motor controller
jpfernandez
Hi
We recived a batch of brand new HCL yesterday and we wanted to add an Aeotec micro motor controller to our system, sadly this wasn't possible.
The HCL is running under 4.044 we added a door sensor a double switch realy and made a scene, working all right so far, but when we tried to add the motor controller clickcing the ID button the system recognize the device but then stall on the device configuration process.
We have been using this devices with HC2 working fine the up, down, pause commands (the slider to set the blinds control no so well), so we are going nuts to find what may be causing this.
We have reseted the HCL Several times trying diferent approaches, but with no luck we always end in the repair website for the HCL
Any comments are welcomed.
Gracias
