Amazon Echo
Acho
    just learned a bit about Amazon Echo - (
). Any chance to integrate it with HC2 ?
Guys , i just updated HABRIDGE to 4.1.2 for google home integration , but i think that was a mistake , now i can't make alexa work again .
I don't know how to add the devices in this new interface of HABRIDGE :( .
I'm at the beginner level in this things so you know :D .
Alexa discover the devices. ( Habridge is working )
Any help?:(
Thank you.
I saw on the BWS thread you were able to fix your issue with the Type that changed to "HTTP Device" with the latest update.  Have you seen any issues changing the dimming settings with your HUE bulbs after the 4.1.2 update?
Thanks!
Matthew
It looks like the format on HA Bridge has been completely changed (v4.1.2) and I have no idea now how to call for Fibaro Scenes? Anyone?
@tcviper. Give this a try
Type should be "HTTP Device", the "Target Item" should be your http URL call and the body should be blank as that is used for POST and PUT methods
For Fibaro i will complete just the :Type and the Target Item.
Edited by matt1981
Error
He guys,
I have the Ha-Bridge new version (4.10) working with Alexa Echo DOT and Fibaro HC2 4.10
Device type: Custom
Map Type: Domoticz Device
Type: Domotics Device
On items: Target: http://<name%40e-mail_domain_name>:<fibro_password>@<IP>/api/callAction?deviceID=<number>&name=turnOn
http: get
Content type: */*
Type Domotics Device:
Dim items: http://<name%40e-mail_domain_name>:<fibro_password>@<IP>/api/callAction?deviceID=<number>&name=setValue&arg1=${intensity.percent}
http: get
Content type: */*
Off items: http://<name%40e-mail_domain_name>:<fibro_password>@<IP>/api/callAction?deviceID=<number>&name=turnOff
http: get
Content type: */*
I asked on Github, here is the answer .
Is working with Alexa and Google Home . ( Tested )
Http Device and Target is the URL Command.
Cheers.
Edited by Daneasa
Didn't see that you already write that :))...Thanks.
Edited by Daneasa
i didnt realize that. i was responding from my phone and it must have not updated properly.. thanks!
i try
but i still getting a Login window.
I try different users but i am not able to Login to the api.
26 minutes ago, gklein said:
i try
Try first this in a browser, check if the device go's On
//<IP>/api/callAction?deviceID=<number>&name=turnOn
When I try full URL with username and pw above in my browser, I get also no output. It works only from HA-Bridge
Twan
Edited by twanve
36 minutes ago, gklein said:
i try
i had to use the format
Cause Fibaro Id requires a login with email adress instead of username in the newest firmware the @ in the email adress is exchanged with %40.
Otherwise it didn't work.
i try the following for example
but still the same problem, it's not working.
i would try messaging the developer. they are very fast to respond and helped me quite a bit.
I think u have 2 // between ip address and the word api
looks like it's not a problem with HDBridge, i think it's a problem with the Fibaro API. Because it's also not working if i try it with a browser.
also try it with one / same problem. Every time i use the api i only get a list of all devices
Try this in you browser;
http://192.1.1.1/api/callAction?deviceID=63&name=turnOn
(stange intern IP adres)
Edited by twanve
this works for me:
http://user:[email protected]/api/callAction?deviceID=199&name=turnOn
Don't use a mail address for username, create a new one and give him necessary rights.
In habridge set "Http verb" to GET and "Content Type" to text/html.
