Amazon Echo
Acho
    just learned a bit about Amazon Echo - (
). Any chance to integrate it with HC2 ?
I don't know how it works in a docker, but can you just stop ha-bridge and start it (so not the container, but only ha-bridge), maybe then it'll work.. It did on my VM.
Got it working with HABridge 4.2.1 on a windows 7 machine with quite fast response aswell.
Thanks all of you that has helped out in this thread!
i erased it on my synology, bought a raspberry pi and install it on the pi....
running great
God to hear you got it working! :-)
I still need to convince my girlfriend we need Alexa in our home :-P
If you tell her she can shop with it im sure she will be convinced ;)
Haha! No actually she is scared it will order stuff by itself!
Hi!
I'll borrow the thread for a bit.
Im running HC2 v4.110 and HA-Bridge 4.1.4. I have successfully managed to add "http://" commands for turning on/off my lights. But i have two Fibaro Dimmer 2 installed. And i can´t get the dimmer command to work. The commands mentioned in "
" video dosen´t work for me.
My working command for On looks like this:
%40gmail.com:[email protected]//api/devices/17/action/turnOn
But i haven´t been able to work out the command for Dim? I want to be able to say "Alexa Dim Kitchen light to 40%" or how ever you have to say it to get Alexa to turn int to 40%.
So i guess all i need is the right "Action" command for dimming? Anyone have any idés? Feel like i have looked everywhere..
Did you fill in HTTP Device and Target and then add it?
Just like you did got On and Off commands.
I only say "Alexa, dim the kitchen lights to 40 procent" and it works
5 minutes ago, Duztmonkey said:
Hi!
hi
I have put the commands in the video plus i have written them on the download file.
But here it is for you.
http://USER%40EMAIL.COM:PASSWORD@IPADDRESS/api/callAction?deviceID=ID&name=setValue&arg1=${intensity.percent}
Sometimes saying 'alexa dim front light to 40 percent ' may not work so you have to say ' alexa turn on front light 40 percent'
1 hour ago, morpheus75 said:
hi
Thanks for a quick reply!
But as i wrote, the commands in the video and the PDF dosen´t work for me.
Example:
Dosen´t work:
http://USER%40EMAIL.COM:PASSWORD@IPADDRESS/api/callAction?deviceID=17&name=turnOn (How is this command meent to look for device #17 with name=light?)
Do work:
http://USER%40MAIL.COM:PASSWORD@IPADRESS//api/devices/17/action/turnOn
How is "http://USER%40EMAIL.COM:PASSWORD@IPADDRESS/api/callAction?deviceID=ID&name=setValue&arg1=${intensity.percent}" meent to look for device number 17 with name = Light?
try this then based on your working commands.
http://USER%40MAIL.COM:PASSWORD@IPADRESS//api/devices/17/action/setValue&arg1=${intensity.percent}
to be honest i dont understand why the standard commands dont work?
your hc2 and habridge are exactly like mine from the videos
Hi, I have followed all the steps and and all the settings in Bridge Control are correct. Commands in Bridge Devices are correct and when I test each device, I get a Successful feedback as seen in attachment. Nevertheless, the HC2 doesn't react. Device doesn't turn on or off.
Echo Dot does recognize the devices.
I'm using
 installed in Raspberry Pi 3
command:
http://user%40email.com:[email protected]//api/devices/5/action/turnOn
thanks for helping
Guest spazpeker
56 minutes ago, ilnyakun said:
which command line should I use?
thank you
http://user%40email.com:[email protected]/api/callAction?deviceID=266&name=turnOn
if your email is [email protected] then would be
http://jim%40hotmail.com:[email protected]/api/callAction?deviceID=266&name=turnOn
Edited by spazpeker
http://blabla%40mail.com:Password@ipadres/api/callAction?deviceID=47&name=turnOn or off
set type to http Device and klick add if you not klick add its not working at all
have you guys been able to get the updated ha-bridge functioning successfully yet?  im contemplating upgrading mine, but i see that there's new issues with the http commands...
thanks
Matt
