Notification on Sprinklers
gusqua
Hi to all
I have my Sprinklers panels configure with 4 zones in the HCL (Fibaro Relay) . I've add a VCL to increase or stop the iirigation depending on the weather.
But i'd like to received any notification if the system doesn´t work properly. The problem that I have is that sometimes the relay go to dead node status and if I do not check the system everyday I will have a problem.
Could anyboy help me on this?
Thanks in advanced
HCL simply does not provide any mechanism to check that in some customized way. However you can create a scene, to check if sprinklers stay off for some time (like 24h) and send push or mail if it does.
  • Solution adopted
